查看: 2582|回复: 2
请教新网格生产技术
发表于 2009-7-1 21:28:16 | 显示全部楼层 |阅读模式
STAR-CD可以用六边形网格(二维)和多面体(三维)网格,据说这样的网格计算量小,效率高。
大家对此类网格怎么看,不知现在又没有其它软件或程序能画这样的网格?谢谢
发表于 2009-7-1 23:58:05 | 显示全部楼层
fluent6.3 以上版本也可以转换出多面体网格:
Support for  polyhedral meshes  is being  introduced in  FLUENT 6.3.   These
    meshes allow  the flexibility  of an  unstructured mesh  to be  applied to a
    complex geometry without  the overhead associated  with a large  tetrahedral
    mesh.  Polyhedral  meshes  are created  using  automatic  cell agglomeration
    within FLUENT 6.3  to combine tetrahedral  cells into polyhedral  ones. This
    can reduce  the overall  cell count  by a  factor of  3 to 5. Alternatively,
    cell-skewness  based  agglomeration  can be  used  to  convert regions  with
    highly-skewed  cells  to  polyhedra,  thereby  improving  mesh  quality. The
    automatic nature of these mesh agglomeration techniques saves the user time,
    and since the polyhedral mesh contains as few as 1/5 the number of cells  in
    the original tetrahedral mesh, convergence is faster.
 楼主| 发表于 2009-7-2 21:54:27 | 显示全部楼层
回复 2# 东岸线 的帖子
谢谢!都说六边形网格或多面体网格计算速度有优势,但不知有没有人用过,具体的结果如何?
这种网格单元数相对较少,但精度如何呢?
