查看: 3103|回复: 1
等离子体的电导率是在什么量级啊?
发表于 2003-11-13 22:08:28 | 显示全部楼层 |阅读模式
弱电离和强电离都分别是哪一个量级的,谢谢。
发表于 2003-11-15 09:41:57 | 显示全部楼层
等离子体的电导率是在什么量级啊?
Your question is too general and is almost equivalent to the following general question:
流体的密度是在什么量级啊?
低密度流体和高密度流体都分别是哪一个量级的,谢谢。
The conductivity of a plasma (i.e., ionized gas) is no longer a scalar but a second order tensor. In other words, the proportionality factor between the electric current density (J = J_bold) and the electric field strength (E = E_bold) in Ohm’s law is a matrix (SIGMA)
J = SIGMA * E
The conductivity in the direction parallel to the magnetic field (SIGMA_0) is often several orders of magnitude greater than those that are perpendicular to the magnetic field. SIGMA_0 depends on several factors. For a weakly ionized plasma (electron-atom collisions are dominant) SIGMA_0 is proportional to T_e^(-1/2) whereas for a strongly ionized plasma (electron-ion collisions are dominant) SIGMA_0 is proportional to T_e^(3/2), where T_e is the electron temperature.
