查看: 13720|回复: 6
求教 单击多核带UDF地并行计算问题
发表于 2009-9-30 11:47:20 | 显示全部楼层 |阅读模式
计算机装的vista系统,UDF的编译通过了,但是初始化时提示:
999999 (..\..\src\mpsystem.c@1123): mpt_read: failed: errno = 10054
The Parallel FLUENT process could not be started.
999999: mpt_read: error: read failed trying to read 4 bytes: No error
unable to read the cmd header on the pmi context, Undefined dynamic error code.
received suspend command for a pmi context that doesn't exist: unmatched id = 3
received suspend command for a pmi context that doesn't exist: unmatched id = 2
received suspend command for a pmi context that doesn't exist: unmatched id = 1
job aborted:
rank: node: exit code[: error message]
0: C405-PC: -1073741819: process 0 exited without calling finalize
1: C405-PC: -1073741819: process 1 exited without calling finalize
2: C405-PC: -1073741819: process 2 exited without calling finalize
3: C405-PC: -1073741819: process 3 exited without calling finalize
请各位大侠多多指点
发表于 2009-10-17 10:09:47 | 显示全部楼层
我也是~
我也出现了这个情况,不知道怎么弄,烦死人了。哪位大侠指点一下
发表于 2009-10-19 20:34:38 | 显示全部楼层
我是新手,来学习一下
发表于 2011-11-16 10:34:50 | 显示全部楼层
iter continuity x-velocity y-velocity     energy          k    epsilon        ch4        h2o         co        co2 surf-mon-1 surf-mon-2 surf-mon-3 surf-mon-4     time/iter
                cells....,EXCEPTION code=ACCESS_VIOLATION
BACKTRACE: 3 stack frames:
#0 0x088e3ae3 at cell_reaction_rates in fl_mpi12016.exe
#1 0x088e2bb0 at Micro_Mixing_Sc in fl_mpi12016.exe
#2 0x08542bb7 at thread_arg in fl_mpi12016.exe
999999 (..\src\mpsystem.c@1148): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 16 bytes: No such file or directory
MPI Application rank 0 exited before MPI_Finalize() with status -1073741819
发表于 2011-11-28 12:39:27 | 显示全部楼层
我采取的方法是重新安装了部分软件,才解决问题。
发表于 2012-2-8 10:15:51 | 显示全部楼层
问题未解决,先谢谢了
发表于 2012-2-8 11:46:32 | 显示全部楼层
并行计算的UDF需要特殊的写法,具体参看fluent帮助
