查看: 3716|回复: 2
想做气液两相,但是参考坐标系一直报错,大虾们给看看
发表于 2010-5-6 18:08:47 | 显示全部楼层 |阅读模式
做一个斜底的气液两相,但是软件一直报错,关于参考坐标系的问题
Domain Group: body
   Buoyancy has been activated.  The absolute pressure will include
   hydrostatic pressure contribution, using the following reference
   coordinates: (-7.79949E+00,-3.21041E-05, 7.50789E-01).
|                     Average Scale Information                      |
Domain Name : body
     Global Length                                         = 1.4357E+01
     Minimum Extent                                        = 1.5600E+01
     Maximum Extent                                        = 1.6300E+01
     Air at 25 C.Density                                   = 1.1850E+00
     Air at 25 C.Dynamic Viscosity                         = 1.8310E-05
     Air at 25 C.Velocity                                  = 1.0000E-01
     Air at 25 C.Advection Time                            = 1.4357E+02
     Air at 25 C.Reynolds Number                           = 9.2919E+04
     Air at 25 C.Mass (Conservative)                       = 3.5070E-12
     Air at 25 C.Mass (Normalised)                         = 3.5070E-12
     Air at 25 C.Volume                                    = 2.9595E-12
     Air at 25 C.Volume Fraction                           = 1.0000E-15
     alcohol.Density                                       = 1.2000E+03
     alcohol.Dynamic Viscosity                             = 7.0000E-01
     alcohol.Velocity                                      = 1.4142E-01
     alcohol.Advection Time                                = 1.0152E+02
     alcohol.Reynolds Number                               = 3.4807E+03
     alcohol.Mass (Conservative)                           = 3.5514E+06
     alcohol.Mass (Normalised)                             = 3.5514E+06
     alcohol.Volume                                        = 2.9595E+03
     alcohol.Volume Fraction                               = 1.0000E+00
     Air at 25 C | alcohol.Slip Reynolds Number            = 8.9077E+00
Domain Name : cube mx
     Global Length                                         = 7.7585E-01
     Minimum Extent                                        = 7.4639E-01
     Maximum Extent                                        = 1.0598E+00
| ERROR #001100279 has occurred in subroutine ErrAction.             |
| This simulation involves a gravity vector which is not aligned wi- |
| th the rotation axis. This is valid only if the simulation type i- |
| s transient, but it is currently set to steady-state. Please chan- |
| ge the setup accordingly.                                          |
|                    Writing crash recovery file                     |
|                An error has occurred in cfx5solve:                 |
| The CFX-5 solver exited with return code 1.   No results file has  |
| been created.                                                      |
End of solution stage.
|                              Warning!                              |
| The CFX-5 Solver has written a crash recovery file.  This file has |
| been saved as D:CFXcfx directoryalcoholbeihai yanzheng_4_gas   |
| and liquid _005.res.err and may be an aid to diagnosing the        |
| problem or restarting the run.  More details should be available   |
| in the solver output section of the output file.  Note that a lock |
| file was left for the crash file when the solver exited, and so it |
| is probably incomplete.                                            |
发表于 2010-5-6 23:13:15 | 显示全部楼层
回复 1# lily228310 的帖子
发表于 2010-5-28 21:05:50 | 显示全部楼层
晕死
