查看: 6509|回复: 4
OpenFOAM 1.7发布
发表于 2010-6-27 20:42:06 | 显示全部楼层 |阅读模式
25th June 2010
OpenCFD are pleased to announce a major, new release of version 1.7.0 of their OpenFOAM open source CFD toolbox. Version 1.7.0 is distributed: (1) as Debian packs created for Ubuntu 10.04 LTS; (2) as source code for compilation on other Linux systems. Version 1.7.0 includes:
Applications
    Numerous new, updated, and demonstration applications for multiphase, heat transfer and reacting flows the include porous regions; particular areas of application include fire simulation and wind/atmospheric flows, supplied with new example cases, e.g. wind turbine siting; reimplementation of numerous solvers to accommodate new changes to the multiphase, buoyant flow and thermo-physical modelling (see below).
Post-processing
    New and improved function objects for on-the-fly calculation of spatial averages, sums, min/max values on fields in sets of cells or faces in the geometry (e.g. for flux calculations across a plane), interpolation of volume fields to surfaces, etc; increased sampling functionality particularly for triangulated surfaces; updated for ParaView 3.8.0.
Boundary conditions
    Implementation of continuous wall function models for turbulence, conjugate heat transfer conditions for turbulent flows, new time varying boundary conditions, new velocity inlet and wall conditions, e.g. swirl inlet, and inlet and far field conditions for wind/atmospheric flows.
Multiphase modelling
    Multiphase and buoyant flow solvers now solve for ∙ prgh = p - ρg x \relax \special {t4ht=, rather than the static pressure p \relax \special {t4ht=, to avoid deficiencies in the handling of the pressure force / buoyant force balance on non-orthogonal and distorted meshes; corresponding improvements made to boundary conditions and pressure referencing in closed domains.
Thermophysical modelling
    Development of thermophysical modelling to redefine the thermodynamics in some solvers in terms of sensible enthalpy instead of total (i.e. including chemical) enthalpy; this was done for improved handling of thermodynamics is the case of partially-premixed or non-premixed combustion systems, or to handle systems with non-unity Lewis number.
Dynamic mesh
    Implementation of six degree-of-freedom, fluid coupled rigid body motion, with various models for restraints (springs and dampers) and constraints (reductions in degrees-of-freedom) that can be applied to simulate things like floating objects and an oscillating wing.
Lagrangian modelling
    Overhaul of the underlying framework with new structure for variable composition, including several new sub-models added for injection, post-processing and patch interaction, evaporation and coal combustion.
Direct simulation Monte-Carlo
    Further developments made to allow 1D and 2D planar simulations; mixed diffuse/specular boundary condition added; new measurements of pressure and wall velocity slip and temperature jump.
Numerics
    MULES algorithm developed to supports sub-cycling on moving meshes for interface capturing VoF (volume of fluid) calculations; further developments to allows a source to be applied to an equation according to an input dictionary at run-time, that can be switched on at particular times and within particular regions of the mesh, using cell zones.
OpenFOAM is produced by OpenCFD — who are Henry Weller, Mattijs Janssens, Chris Greenshields, Andy Heather, Sergio Ferraris, Graham Macpherson, Helene Blanchonnet and Jenya Collings — with external contributions from Mark Olesen.
转自OpenFOAM官方网站
http://www.openfoam.com/download/index.php
[ 本帖最后由 OpenFOAM 于 2010-6-27 20:45 编辑 ]
 楼主| 发表于 2010-6-27 20:44:57 | 显示全部楼层
回复 1# OpenFOAM 的帖子
与以前的版本不同现在好像仅有debian包,目前官方支持Ubuntu 10.04 LTS 32bit/64bit
当然还有源码包,不过需要自己编译.
1.7.x版本尚未公布.
发表于 2010-6-30 11:31:43 | 显示全部楼层
有代码包的。
 楼主| 发表于 2010-7-2 19:40:51 | 显示全部楼层
现在好像可以通过git下载 1.7.x了
发表于 2010-9-29 10:27:24 | 显示全部楼层
请问楼主如何下载openfoam啊,找了半天也没有,多谢楼主
