查看: 4608|回复: 2
遇到类似问题的大侠请赐教!!急!
发表于 2011-3-7 10:46:51 | 显示全部楼层 |阅读模式
Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc Grad of Wall Dist, size 31606776, t 2, myid 1000000.
Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc Reconstruction Min, size 10535592, t 2, myid 1000000.
Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc Reconstruction Max, size 10535592, t 2, myid 1000000.
Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc Reconstruction Phi, size 10535592, t 2, myid 1000000.
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
Error Object: ()
发表于 2011-3-7 12:35:22 | 显示全部楼层
内存不够,减少网格。
发表于 2011-3-25 11:07:22 | 显示全部楼层
加大内存就行了
