查看: 4649|回复: 1
菜鸟在fluent中遇到个问题
发表于 2011-3-13 13:53:21 | 显示全部楼层 |阅读模式
absolute pressure limited to 1.000000e+000 in 22 cells on zone 2  turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 33 cells
    39 2.4241e+00 9.8608e-04 9.3968e-04 1.3676e-03 8.5402e-02  0:01:29  261
temperature limited to 1.000000e+000 in 78 cells on zone 2 in domain 1
absolute pressure limited to 1.000000e+000 in 24 cells on zone 2  turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 31 cells
    40 2.4413e+00 1.0275e-03 1.0062e-03 2.7195e-03 8.3903e-02  0:01:11  260
temperature limited to 1.000000e+000 in 76 cells on zone 2 in domain 1
  temperature limited to 5.000000e+003 in 2 cells on zone 2 in domain 1
absolute pressure limited to 1.000000e+000 in 14 cells on zone 2  turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 35 cells
    41 2.9766e+00 1.1033e-03 1.0197e-03 2.1440e-03 5.9544e-02  0:01:48  259
temperature limited to 1.000000e+000 in 59 cells on zone 2 in domain 1
absolute pressure limited to 1.000000e+000 in 12 cells on zone 2  turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 35 cells
    42 2.4091e+00 1.3256e-03 2.0894e-03 1.5770e-02 6.7634e-02  0:01:26  258
temperature limited to 1.000000e+000 in 47 cells on zone 2 in domain 1
不知这是网格划分不合适,还是其他的问题?
发表于 2011-3-28 08:47:41 | 显示全部楼层
把scale转换一下就行了,网格单位的问题
