查看: 6043|回复: 1
blockMesh: /usr/lib/libstdc++.so.6: version `CXXABI_1.3.1' not found
发表于 2011-3-16 23:33:23 | 显示全部楼层 |阅读模式
大家好,我用gcc43编译of1.7.1,编译完后运行测试例子cavity,执行blockMesh时,出现如下错误信息。
blockMesh: /usr/lib/libstdc++.so.6: version `CXXABI_1.3.1' not found (required b y blockMesh)
blockMesh: /usr/lib/libstdc++.so.6: version `CXXABI_1.3.1' not found (required b y /home/alank/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libmeshTools.so)
blockMesh: /usr/lib/libstdc++.so.6: version `CXXABI_1.3.1' not found (required b y /home/alank/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libdynamicMesh.so)
blockMesh: /usr/lib/libstdc++.so.6: version `CXXABI_1.3.1' not found (required b y /home/alank/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libOpenFOAM.so)
blockMesh: /usr/lib/libstdc++.so.6: version `CXXABI_1.3.1' not found (required b y /home/alank/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libtriSurface.so)
blockMesh: /usr/lib/libstdc++.so.6: version `CXXABI_1.3.1' not found (required b y /home/alank/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libfiniteVolume.so)
这是安装之后,测试的结果。
./foamInstallationTest
Executing ./foamInstallationTest:
Checking basic setup...
Shell:              bash
Host:               node01
OS:                 Linux version 2.6.16.60-0.21-smp
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory                Valid      Crit
$WM_PROJECT_INST_DIR /home/users/test/OpenFOAM             yes       yes
$WM_PROJECT_USER_DIR ...users/test/OpenFOAM/ectest3-1.7.1  yes       no
$WM_THIRD_PARTY_DIR  ...rs/test/OpenFOAM/ThirdParty-1.7.1  yes       yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory                Valid Path Crit
$WM_PROJECT_DIR      ...sers/test/OpenFOAM/OpenFOAM-1.7.1  yes  yes  yes
$FOAM_APPBIN         ...7.1/applications/bin/linux64GccDPOpt  yes  yes  yes
$FOAM_SITE_APPBIN    ...nFOAM/site/1.7.1/bin/linux64GccDPOpt  no        no
$FOAM_USER_APPBIN    ...7.1/applications/bin/linux64GccDPOpt  no        no
$WM_DIR              ...test/OpenFOAM/OpenFOAM-1.7.1/wmake  yes  yes  yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN         ...M/OpenFOAM-1.7.1/lib/linux64GccDPOpt  yes  yes  yes
$FOAM_SITE_LIBBIN    ...nFOAM/site/1.7.1/lib/linux64GccDPOpt  no        no
$FOAM_USER_LIBBIN    ...AM/ectest3-1.7.1/lib/linux64GccDPOpt  no        no
$MPI_ARCH_PATH       ...1/platforms/linux64Gcc/openmpi-1.4.1  yes  yes  yes
Third party software
Software Version   Location
gcc      4.3.3     /home/users/test/gcc/gcc-4.3.3/platforms/bin/gcc
gzip     1.3.5     /usr/bin/gzip
tar      1.15.1    /bin/tar
icoFoam            ...penFOAM-1.7.1/applications/bin/linux64GccDPOpt/icoFoam
Summary
Base configuration ok.
Critical systems ok.
done.
还望各位指定。谢谢。
[ 本帖最后由 volwang 于 2011-3-16 15:35 编辑 ]
发表于 2011-3-17 15:11:14 | 显示全部楼层
是不是后面又编译了什么..
你可以试试看solver 可能也有类似的毛病.
