查看: 3434|回复: 2
linux下采用何种后处理软件?
发表于 2002-10-25 07:49:19 | 显示全部楼层 |阅读模式
最近在linux下编程,没可用的后处理软件。tecplot总是找不到linux 版本的,不知高手们都使用的什么软件看结果。请不吝赐教!谢谢!
oldcfd@hotmail.com
发表于 2002-10-25 07:56:16 | 显示全部楼层
linux下采用何种后处理软件?
1) you might install vmware under Linux, with that software , you could install winodws and then you could install tecplot for yourself.
2) I used to use gnuplot to draw the curve for 2d , but I guess you could use it to draw 3D curve, too.
 楼主| 发表于 2002-10-25 10:07:48 | 显示全部楼层
linux下采用何种后处理软件?
Thanks!
