查看: 3243|回复: 1
火焰速度 和 爆炸速度有什么区别?
发表于 2011-4-11 16:54:20 | 显示全部楼层 |阅读模式
还有火焰速度是绝对速度(比如相对燃烧器)还是相对速度(火焰相对未燃气体)?
 楼主| 发表于 2011-4-11 20:15:33 | 显示全部楼层
回复 1# ahunter 的帖子
The flame speed is the measured rate of expansion of the flame front in a combustion reaction. Whereas flame speed is generally used for a fuel, a related term is explosive velocity, which is the same relationship measured for an explosive. Combustion engineers differentiate between the laminar and turbulent flame speeds. Flame speed is typically measured in m/s, cm/s, etc.
