查看: 5483|回复: 5
Fluent UDF 求力
发表于 2016-6-19 11:27:30 | 显示全部楼层 |阅读模式
楼主算多个机翼的受力,用DEFINE_EXECUTE_AT_END 和 Compute_Force_And_Moment 宏 求合力
但是如果同时求多个 机翼的受力Compute_Force_And_Moment (domain, tf1, x1_cg, f1_glob, m1_glob,1);
                                                   Compute_Force_And_Moment (domain, tf2, x2_cg, f2_glob, m2_glob,1);
                                                    Compute_Force_And_Moment (domain, tf3, x3_cg, f3_glob, m3_glob,1);
                                                   Compute_Force_And_Moment (domain, tf4, x4_cg, f4_glob, m4_glob,1);
就会出现 fl1450s.exe received fatal signal (ACCESS_VIOLATION) 的错误
只保留上面一个,注释掉其他几个就没有问题 ,请问这是什么原因,如何解决?
DEFINE_EXECUTE_AT_END(Force_and_Power)
        real  f1_glob[ND_ND],m1_glob[ND_ND],x1_cg[ND_ND];
        real  f2_glob[ND_ND],m2_glob[ND_ND],x2_cg[ND_ND];
        real  f3_glob[ND_ND],m3_glob[ND_ND],x3_cg[ND_ND];
        real  f4_glob[ND_ND],m4_glob[ND_ND],x4_cg[ND_ND];
        real  f5_glob[ND_ND],m5_glob[ND_ND],x5_cg[ND_ND];
        real  f6_glob[ND_ND],m6_glob[ND_ND],x6_cg[ND_ND];
    real  f1,f3,f5;
    Domain *domain= Get_Domain (1);
    Thread *tf1 = Lookup_Thread (domain, 58);
        //Thread *tf2 = Lookup_Thread (domain, 59);
        //Thread *tf3 = Lookup_Thread (domain, 60);
        //Thread *tf4 = Lookup_Thread (domain, 61);
        Thread *tf5 = Lookup_Thread (domain, 62);
        //Thread *tf6 = Lookup_Thread (domain, 63);
   if(N_TIME>2){
      x1_cg[0]=x1_cg[1]=0.000;
      x2_cg[0]=x2_cg[1]=0.000;
          x3_cg[0]=x3_cg[1]=0.000;
          x4_cg[0]=x4_cg[1]=0.000;
          x5_cg[0]=x5_cg[1]=0.000;
          x6_cg[0]=x6_cg[1]=0.000;
      //Compute_Force_And_Moment (domain, tf2, x2_cg, f2_glob, m2_glob,1);
          //Compute_Force_And_Moment (domain, tf3, x3_cg, f3_glob, m3_glob,1);
          //Compute_Force_And_Moment (domain, tf4, x4_cg, f4_glob, m4_glob,1);
          Compute_Force_And_Moment (domain, tf5, x5_cg, f5_glob, m5_glob,1);
          //Compute_Force_And_Moment (domain, tf6, x6_cg, f6_glob, m6_glob,1);
      f1=f1_glob[0]+f5_glob[0];   //+f3_glob[0]+f4_glob[0]+f5_glob[0]+f6_glob[0];
      f3=f1_glob[1]+f5_glob[1];   //+f3_glob[1]+f4_glob[1]+f5_glob[1]+f6_glob[1];
      f5=m1_glob[2]+m5_glob[2];   //+m3_glob[2]+m4_glob[2]+m5_glob[2]+m6_glob[2];
          fpo=fopen("Power_All.dat", "a+");
      fprintf(fpo,"%8.5f %12.5f %12.5f\n",CURRENT_TIME*w/(2*PI),f1*U,f5*w);
          fclose(fpo);}
// non-dimension disposal
      f1 = f1/(rou*Nt*Nt*8*Radius*Radius*Radius*L);
      f3 = f3/(rou*Nt*Nt*8*Radius*Radius*Radius*L);
      f5 = f5/(rou*Nt*Nt*16*Radius*Radius*Radius*Radius*L);
      fpc=fopen("Force_All.dat", "a+");
      fprintf(fpc,"%8.5f %12.8f %12.8f %12.8f\n",CURRENT_TIME*w/(2*PI),f1,f3,f5);
          fclose(fpc);
// test
          fpc1=fopen("force_1.dat", "a+");
      fprintf(fpc1,"%8.5f %10.5f %10.5f %10.5f\n",CURRENT_TIME*w/(2*PI),f1_glob[0],f1_glob[1],m1_glob[2]);
          fclose(fpc1);
发表于 2016-6-20 21:17:32 | 显示全部楼层
可以尝试
求这个翼片的受力并记录
     Thread *tf1 = Lookup_Thread (domain, 59);
求这翼片受力并记录
最后累加
 楼主| 发表于 2016-6-21 18:47:16 | 显示全部楼层
aaa-1234 发表于 2016-6-20 21:17
可以尝试
求这个翼片的受力并记录
谢谢!我试试
发表于 2016-6-22 11:30:40 | 显示全部楼层
可不可行都上来报告一下,谢谢!
 楼主| 发表于 2016-6-22 19:38:45 | 显示全部楼层
aaa-1234 发表于 2016-6-22 11:30
可不可行都上来报告一下,谢谢!
我用另一个办法解决的。
我在每个机翼的 DEFINE_CG_MOTION 里 求Compute_Force_And_Moment (),保存到全局变量里,
再在DEFINE_EXECUTE_AT_END() 求和
发表于 2016-6-28 16:55:43 | 显示全部楼层
Domain *domain= Get_Domain (1);    Thread *tf1 = Lookup_Thread (domain, 58),把domain改成你相应的body名称,试一试
