查看: 1745|回复: 2
gambit安装不能用,提示如图,大神帮忙啊。
发表于 2013-5-22 13:24:36 | 显示全部楼层 |阅读模式
发表于 2013-5-22 13:27:28 | 显示全部楼层
没明白是什么问题,应该是安装有问题吧
或者是license有问题?
 楼主| 发表于 2013-5-22 15:15:53 | 显示全部楼层
回复 2# a2883524 的帖子
这个是窗口提示
Locating Exceed installation ...
Launching Exceed 13 ...
Starting D:\PROGRA~1\Fluent.Inc\Gambit\gambit2.4.6\ntx86\gambit.exe -device open -id default_id10912 -new  ...
Gambit build SP2007051421.
Received exception: SIGSEGV (segmentation violation)
Please send the GAMBIT.10540/jou and GAMBIT.10540/trn files to your local
Fluent office or distributor.  Also send a message including any
relevant errors or warnings you see above in this window.  You may
wish to delete the temporary directory GAMBIT.10540 after sending the
above files.
ERROR: Please retain a copy of the GAMBIT.10540/jou, GAMBIT.10540/trn, and
GAMBIT.10540/*.dbs files, any imported geometry and any relevant
errors or warnings you see above in this window and contact
support at your local Fluent office or distributor.
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
我改license了,也不行,我本来是安装能用的,不知道为什么今天打开就不能用了,好像电脑更新系统补丁后。
