返回列表 发新帖
楼主: zyf
[求助]哪里有移动网格的程序?二维的就行
发表于 2003-5-22 22:56:04 | 显示全部楼层
part2
发表于 2003-5-22 22:57:17 | 显示全部楼层
part3
发表于 2003-5-22 22:57:58 | 显示全部楼层
part4
发表于 2003-5-22 22:59:00 | 显示全部楼层
part5
发表于 2003-5-22 23:01:27 | 显示全部楼层
part6
发表于 2003-5-23 20:31:01 | 显示全部楼层
谢谢了
发表于 2003-5-24 00:30:49 | 显示全部楼层
程序的交流在于互相促进与提高。国内的CFD水平上不去,在于交流。 希望看完程
序并加了PDF Solver后的Code 能加到这个贴上。如果人人都是想得到些什么而不付
出什么,那么就达不到互相促进与提高来带动我国的CFD水平的目的了。
大侠们多努力吧。
发表于 2003-5-24 00:38:09 | 显示全部楼层
我有如下PDF solver, 看看那个对这个问题合适,谁要可与我联系(包括说明和CODE)。
D03EAF Example Text Example Data  7 Elliptic PDE, Laplace's equation, two-dimensional arbitrary domain
D03EBF Example Text  7 Elliptic PDE, solution of finite difference equations by SIP, five-point two-dimensional molecule, iterate to convergence
D03ECF Example Text  8 Elliptic PDE, solution of finite difference equations by SIP for seven-point three-dimensional molecule, iterate to convergence
D03EDF Example Text  12 Elliptic PDE, solution of finite difference equations by a multigrid technique
D03EEF Example Text  13 Discretize a second-order elliptic PDE on a rectangle
D03FAF Example Text  14 Elliptic PDE, Helmholtz equation, three-dimensional Cartesian co-ordinates
D03MAF Example Text  7 Triangulation of plane region
D03NCF Example Text Example Data  20 Finite difference solution of the Black–Scholes equations
D03NDF Example Text Example Data  20 Analytic solution of the Black–Scholes equations
D03NEF Example Text Example Data  20 Compute average values for D03NDF
D03PCA Example Text  20 General system of parabolic PDEs, method of lines, finite differences, one space variable (thread safe)
D03PCF Example Text  15 General system of parabolic PDEs, method of lines, finite differences, one space variable
D03PDA Example Text  20 General system of parabolic PDEs, method of lines, Chebyshev C0 collocation, one space variable (thread safe)
D03PDF Example Text  15 General system of parabolic PDEs, method of lines, Chebyshev C0 collocation, one space variable
D03PEF Example Text  16 General system of first-order PDEs, method of lines, Keller box discretisation, one space variable
D03PFF Example Text  17 General system of convection-diffusion PDEs with source terms in conservative form, method of lines, upwind scheme using numerical flux function based on Riemann solver, one space variable
D03PHA Example Text  20 General system of parabolic PDEs, coupled DAEs, method of lines, finite differences, one space variable (thread safe)
D03PHF Example Text  15 General system of parabolic PDEs, coupled DAEs, method of lines, finite differences, one space variable
D03PJA Example Text  20 General system of parabolic PDEs, coupled DAEs, method of lines, Chebyshev C0 collocation, one space variable (thread safe)
D03PJF Example Text  15 General system of parabolic PDEs, coupled DAEs, method of lines, Chebyshev C0 collocation, one space variable
D03PKF Example Text  16 General system of first-order PDEs, coupled DAEs, method of lines, Keller box discretisation, one space variable
D03PLF Example Text Example Data  17 General system of convection-diffusion PDEs with source terms in conservative form, coupled DAEs, method of lines, upwind scheme using numerical flux function based on Riemann solver, one space variable
D03PPA Example Text  20 General system of parabolic PDEs, coupled DAEs, method of lines, finite differences, remeshing, one space variable (thread safe)
D03PPF Example Text  16 General system of parabolic PDEs, coupled DAEs, method of lines, finite differences, remeshing, one space variable
D03PRF Example Text  16 General system of first-order PDEs, coupled DAEs, method of lines, Keller box discretisation, remeshing, one space variable
D03PSF Example Text  17 General system of convection-diffusion PDEs with source terms in conservative form, coupled DAEs, method of lines, upwind scheme using numerical flux function based on Riemann solver, remeshing, one space variable
D03PUF  17 Roe's approximate Riemann solver for Euler equations in conservative form, for use with D03PFF, D03PLF and D03PSF
D03PVF  17 Osher's approximate Riemann solver for Euler equations in conservative form, for use with D03PFF, D03PLF and D03PSF
D03PWF Example Text Example Data  18 Modified HLL Riemann solver for Euler equations in conservative form, for use with D03PFF, D03PLF and D03PSF
D03PXF Example Text Example Data  18 Exact Riemann Solver for Euler equations in conservative form, for use with D03PFF, D03PLF and D03PSF
D03PYF  15 PDEs, spatial interpolation with D03PDF or D03PJF
D03PZF  15 PDEs, spatial interpolation with D03PCF, D03PEF, D03PFF, D03PHF, D03PKF, D03PLF, D03PPF, D03PRF or D03PSF
D03RAF Example Text  18 General system of second-order PDEs, method of lines, finite differences, remeshing, two space variables, rectangular region
D03RBF Example Text  18 General system of second-order PDEs, method of lines, finite differences, remeshing, two space variables, rectilinear region
D03RYF  18 Check initial grid data in D03RBF
D03RZF  18 Extract grid data from D03RBF
D03UAF Example Text  7 Elliptic PDE, solution of finite difference equations by SIP, five-point two-dimensional molecule, one iteration
D03UBF Example Text  8 Elliptic PDE, solution of finite difference equations by SIP, seven-point three-dimensional molecule, one iteration
发表于 2003-5-25 12:12:19 | 显示全部楼层
thank you  sillybear
发表于 2003-6-9 13:30:41 | 显示全部楼层
赞成sillybear老兄的提议!
