发表于 2014-5-16 23:47:07
The corner of the step is the center of rarefaction fan and hence is a singular point of the flow. Frankly speaking the flow is seriously affected by large numerical errors generated just in the neighborhood of this singular point if nothing special is not undertaken. The modern study shown that the presence of such point in flow may lead to phase – time delay [3]. Generally there are two ways to reduce or eliminate this point. The original idea was proposed by Woodward [2] and consisted of applying special boundary conditions near the corner of the step, which is based on the assumption of a nearly steady flow in this region. The density was reset here so that the entropy has the same value as in the zone just to the left and below the corner of the step. The magnitudes of velocities (but no their directions) were reset also, so that the sum of enthalpy and kinetic energy per unit mass has the same value as in the same zone to set the entropy. More sophisticated and accurate approach may be applied to solve this problem at present. One can make a little fillet to avoid the straight angle in the step corner. Robust unstructured meshes allow additionally preparing some grid refinement in this region.
这是关于前台阶流角点的处理,求解释!! |
