查看: 7203|回复: 1
fluent中多孔介质孔隙率的设置
发表于 2011-5-15 21:25:13 | 显示全部楼层 |阅读模式
请问大家fluent中多孔介质孔隙率可以用自定义函数导入fluent中吗?谢谢各位
发表于 2011-8-22 10:56:07 | 显示全部楼层
可以的,在FLUENT USER'S GUIDE中有这么一句话“
You can also define the porosity using a user-defined function (UDF). The user-defined option becomes available in the corresponding drop-down list when the UDF has been created and loaded into ANSYS FLUENT. Note that the porosity defined in the UDF must utilize the DEFINE_PROFILE macro. For more information on creating and using user-defined function, see the separate UDF Manual.
