查看: 1847|回复: 2
fluent 计算求助
发表于 2011-5-19 20:34:02 | 显示全部楼层 |阅读模式
计算出现下面的情况,请大家指点一下,这是什么原因?
iter continuity x-velocity y-velocity z-velocity     energy     time/iter
     1 1.0000e+00 6.0795e+03 9.0325e-02 1.2402e-02 1.9405e-08  0:16:20   49
reversed flow in 10233 faces on pressure-inlet 8.
reversed flow in 23 faces on pressure-inlet 9.
reversed flow in 642 faces on pressure-inlet 10.
reversed flow in 409 faces on pressure-inlet 11.
reversed flow in 646 faces on pressure-inlet 12.
reversed flow in 1206 faces on pressure-outlet 6.
Error: divergence detected in AMG solver: temperature
Error Object: ()
发表于 2011-5-19 20:53:15 | 显示全部楼层
这个应该是发散了
 楼主| 发表于 2011-5-19 22:58:56 | 显示全部楼层
回复 2# fjh2009 的帖子
有什么办法可以解决吗?
