查看: 1609|回复: 0
fluent运算错误求解答,十万火急
发表于 2011-5-21 22:07:53 | 显示全部楼层 |阅读模式
我计算的时候经常出现下面几句话:
reversed flow in 72 faces on pressure-inlet 4.
reversed flow in 1029 faces on pressure-outlet 6.
time step reduced in 16 cells
temperature limited to 5.000000e+003 in 1 cells on zone 2
turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 400548 cells
算到最后,出现
Error: Floating point error: invalid number
Error Object: ()
这是怎么回事啊??那儿出问题了
补充:物性参数由于是变化的,我采用了分段多项式拟合  是不是那里出问题了?
