查看: 1915|回复: 1
fluent 6.3解读
发表于 2006-12-9 18:01:42 | 显示全部楼层 |阅读模式
   In FLUENT  6.3, a  pressure-based coupled  solver joins  the existing solver
    options.  This  new  solver  can  improve  solution  efficiency  as  well as
    convergence and  robustness for  many cases.  With this  solver scheme,  the
    pressure and velocity equations are solved in a fully coupled manner,  while
    the other equations are  solved sequentially. It is  particularly beneficial
    for “stiff”  problems and  for solving  problems on  unusually skewed  and
    stretched meshes.
    对该问题一个疑问,基于压力的耦合算法,不知是不是针对SIMPLEC的分离算法而言的,
    如果这样,主要就是求解低速问题,解决数值求解过程中的刚性问题。
    这种算法和目前的预处理或预条件算法有什么根本性的差异,不大明白,请指点。
    In addition to this new solver,  the existing solvers have been enhanced  to
    offer improved  robustness, accuracy,  and efficiency.  For example,  strong
    shocks can now be captured  more effectively with the density-based  solver,
    and transient  simulations can  be run  more efficiently  with the  pressure
    -based solver. Additionally,  a new diagnostic  case check algorithm  can be
    used  to  assess case  settings  and offer  recommendations  to ensure  that
    commonly accepted best practices are being used.
    从后续的说明来看,似乎印证了我的猜测。因为提高了强激波流动采用密度基的算法,
    也就是我们通常说的可压缩流动求解方法,EULER或者N-S方程,但是后面又提到了对于
    瞬态问题采用压力基算法,这样又一次陷入了迷惑之中。
    Support for  polyhedral meshes  is being  introduced in  FLUENT 6.3.   These
    meshes allow  the flexibility  of an  unstructured mesh  to be  applied to a
    complex geometry without  the overhead associated  with a large  tetrahedral
    mesh.  Polyhedral  meshes  are created  using  automatic  cell agglomeration
    within FLUENT 6.3  to combine tetrahedral  cells into polyhedral  ones. This
    can reduce  the overall  cell count  by a  factor of  3 to 5. Alternatively,
    cell-skewness  based  agglomeration  can be  used  to  convert regions  with
    highly-skewed  cells  to  polyhedra,  thereby  improving  mesh  quality. The
    automatic nature of these mesh agglomeration techniques saves the user time,
    and since the polyhedral mesh contains as few as 1/5 the number of cells  in
    the original tetrahedral mesh, convergence is faster.
    fluent6.3采用了多面体网格策略,这一点就是聚合网格(cell agglomeration)的思路。
    国内的631所朱培烨先生对此做了研究,但是如何实现自动聚合,以及聚合的判断标准,
    不知道和自适应网格有神似的地方没有?迷惑
    In support of FLUENT’s ongoing commitment to parallel processing,  numerous
    improvements to  parallel efficiency  and flexibility  have been implemented
    along with speed improvements for  reading and writing case and  data files.
    HPC customers  can also  benefit from  running Fluent  6.3 on 64-bit Windows
    platforms such as Windows Compute Cluster Server 2003.
    从这一段话中,多少能够看到FLUENT在计算效率方面所做的努力,fluent的一个最大的
    特点和缺点就是对资源的占用和冗长的计算过程,这对理论研究倒不是什么瓶颈,但是
    要在工程设计中应用,这就是一个最大的缺点了,除非,为了FLUENT专门购置高性能工作
    站,而这一点似乎是FLUENT所推崇的。个人之见!文字[color=#0000FF]文字[color=#0000FF]文字[color=#0000FF]文字[color=#0000FF]文字
发表于 2006-12-9 18:35:46 | 显示全部楼层
fluent 6.3解读
愿闻高见,支持一下。
