查看: 2707|回复: 10
[分享]fluent程序验证与考核报告
发表于 2006-12-26 09:36:31 | 显示全部楼层 |阅读模式
[这个贴子最后由CFDNHT在 2008/05/31 03:50am 第 3 次编辑]
Abstract
The FLUENT 6 CFD code has been benchmarked for a wide range of simple, classical,and complex physical problems associated with turbulent gas flow, natural convection,and turbulent mixing phenomena. The results validate the application of previous scoping calculations for the Tank 50/Tank 48 vapor space mixing.
The benchmarked problems consisted of three groups. The first group was well-defined and classical problems for which analytical solutions exist. The other groups are complex and physical problems for which analytical solutions are difficult to obtain. For these test problems, CFD results were compared and verified through comparisons with experimental results. The benchmarking of the FLUENT 6 code showed that the code predictions are in good agreement with the analytical solutions or experimental test data.
The code was shown to be sufficiently accurate to make reliable decisions based on calculated results for those applications that fall within the scope of the benchmarking test cases. For applications that fall outside the range of the benchmarking results,particularly for significantly higher benzene concentrations or for flow geometries not adequately represented by the k- ε turbulence model, further benchmarking work would be required.
发表于 2006-12-26 10:05:08 | 显示全部楼层
[分享]fluent程序验证与考核报告
介绍一下吧!太贵了,也让我们知道是否物有所值啊?
发表于 2006-12-26 12:53:14 | 显示全部楼层
[分享]fluent程序验证与考核报告
无语……
发表于 2006-12-26 13:14:34 | 显示全部楼层
[分享]fluent程序验证与考核报告
掏钱了,也没下下来。。
怀疑有假呀[br][br][以下内容由 rener 在 2006年12月31日 11:16am 时添加] [br]
renzhongjunhvac@163.com
下不了。。
好像是有问题。。
拜托发到邮箱吧
 楼主| 发表于 2006-12-26 15:30:02 | 显示全部楼层
[分享]fluent程序验证与考核报告
现在可以了。介绍见Abstract
发表于 2006-12-26 16:38:56 | 显示全部楼层
[分享]fluent程序验证与考核报告
kankan
ding xia
发表于 2006-12-26 23:21:58 | 显示全部楼层
[分享]fluent程序验证与考核报告
到底是什么东西呢!!!!!!!!!说清楚一些
发表于 2006-12-28 10:42:19 | 显示全部楼层
[分享]fluent程序验证与考核报告
Abstract
这事楼主里面的Abstract
谢谢楼主
[br][br][以下内容由 guzi1112 在 2006年12月28日 10:49am 时添加] [br]
楼主有骗钱嫌疑,下载不下来,请楼主快快修复链接,或者发到我的信箱,谢谢
guzi1112@163.com
发表于 2006-12-28 11:39:05 | 显示全部楼层
[分享]fluent程序验证与考核报告
看 了Abstract,感觉好象FLUENT公司的宣传册子,你怎么拿来卖钱?
发表于 2006-12-30 21:04:24 | 显示全部楼层
[分享]fluent程序验证与考核报告
先买了再说吧
发表于 2007-1-22 09:40:58 | 显示全部楼层
[分享]fluent程序验证与考核报告
ding sadly
