查看: 2645|回复: 1
用hypermesh画网格的问题
发表于 2011-7-27 10:43:26 | 显示全部楼层 |阅读模式
为什么我画好hypermesh的网格输入fluent后,fluent会把boundary和cell zone搞混。Reading "C:\Users\Administrator\Documents\test17.cas"...
       Clearing partially read grid.
   29006 nodes.
   48839 mixed cells, zone  1.
   60473 mixed cells, zone  2.
Changing thread id 1 to 3
   86293 mixed interior faces, zone  3.
Changing thread id 2 to 4
  111888 mixed interior faces, zone  4.
Changing thread id 4 to 5
      72 mixed pressure-inlet faces, zone  5.
Changing thread id 5 to 6
      43 mixed pressure-outlet faces, zone  6.
    9920 mixed wall faces, zone 15.
   11091 mixed wall faces, zone 16.
    1644 mixed symmetry faces, zone 17.
    4916 mixed wall faces, zone 22.
   13200 mixed wall faces, zone 24.
Building...
     mesh
     materials,
     interface,
     domains,
     zones,
        default-exterior
        wall2
        symmetry
        wall
        heatwall
        outlet
        inlet
        cells
        fluid
        pressure-outlet-6
        interior-3
Done.
Preparing mesh for display...
Done.
Warning: Both outflow and pressure boundaries are present in the
         domain. This is an incompatibility and solution cannot
         proceed until this is fixed.
 楼主| 发表于 2011-7-27 12:33:57 | 显示全部楼层
