查看: 2911|回复: 1
PROE模型导入ICEM出错
发表于 2011-8-12 08:46:28 | 显示全部楼层 |阅读模式
请教各位大侠,我要建的模型相对有点复杂,所以采用PROE来建模,但是导入ICEM后,模型有失真,尤其是在一些圆弧面上,我经过很长时间的修复,本以后都修复好了,但是再次打开文件却出现一堆这样的问题,这些是不是意味着模型仍然有很多问题,大家都是怎么解决这种导入后出现的问题的?
roblems with coedge curve F_31577e5042.10 of surface F_31577.cut.0
problems with coedge curve F_31577e5042.4 of surface F_31577.cut.0
problems with surface F_31577.cut.0 could not be fixed
problems with coedge curve topo_surf/684e2294.2 of surface topo_surf/684
problems with coedge curve E_42296.2 of surface topo_surf/684
problems with surface topo_surf/684 could not be fixed
problems with coedge curve topo_surf/689e1266.2 of surface topo_surf/689
problems with coedge curve E_53950 of surface topo_surf/689
发表于 2011-8-12 22:11:00 | 显示全部楼层
转成CATIA V4格式试试
