查看: 8889|回复: 7
求救!!fluent并行计算问题
发表于 2011-10-14 17:08:23 | 显示全部楼层 |阅读模式
最近在做fluent的并行计算,收集了很多资料,但还是迟迟不能成功,恳请高手不吝赐教!下面是我所遇问题的描述:
1.我安装了rshd,在dos命令中输入C:\Fluent.Inc\ntbin\ntx86\fluent.exe -r6.3.26 3d -t2 启动fluent的并行版本,读入cas和dat文件,auto partition--->load balance--->initialize--->iterate,出现如下报错信息后终止计算:
iter continuity x-velocity y-velocity z-velocity     time/iter
     1 1.0000e+00 2.4150e-06 0.0000e+00 0.0000e+00  0:08:12   99
     2 1.0000e+00 1.9171e-01 8.8890e-02 3.7446e-03  0:08:08   98
     3 8.1443e-01 4.7322e-02 3.1924e-02 5.2688e-03  0:07:44   97
     4 3.8177e-01 1.8762e-02 1.2399e-02 1.9531e-03  0:07:43   96
     5 3.0533e-01 9.9340e-03 8.0227e-03 1.5070e-03  0:07:42   95
>> Dividing domain into 256 partitions using Principal Axes.
.................................................. 50
.................................................. 100
.................................................. 150
.................................................. 200
.................................................. 250
..... 255 bisections.
   Smoothing partition boundaries...
   Checking for orphan clusters...
   Time = 8.25 seconds.
   Done.
>> 256 Stored Partitions:
   Collective Partition Statistics:        Minimum   Maximum   Total
   Cell count                              2634      2791      694436
   Mean cell count deviation               -2.9%     2.9%
   Partition boundary cell count           595       2216      268651
   Partition boundary cell count ratio     21.9%     81.7%     38.7%
   Face count                              8818      9532      2108843
   Mean face count deviation               -3.1%     4.8%
   Partition boundary face count           831       2646      220660
   Partition boundary face count ratio     9.4%      27.8%     10.5%
   Partition neighbor count                2         15
   Partition Method                        Principal Axes
   Stored Partition Count                  256
Done.
999999 (..\..\src\mpsystem.c@1123): mpt_read: failed: errno = 10014
999999: mpt_read: error: read failed trying to read 1024 bytes: No such file or directory
0 (..\..\src\mpsystem.c@1123): mpt_read: failed: errno = 10054
0: mpt_read: error: read failed trying to read 4 bytes: No error
The Parallel FLUENT process could not be started.
unable to read the cmd header on the pmi context, Undefined dynamic error code.
job aborted:
rank: node: exit code[: error message]
0: OO: -1: process 0 exited without calling finalize
1: OO: 123
这是什么意思呢?
2. 在采用上述设置时,有时候也可以计算,偶尔会有提示说信息传递成功,但是时断时续,很不稳定,请问这要怎么解决?为什么有时候又出现问题1那种情况呢?
3. 听说要安装mpi,于是我依提示安装,可是在注册时出现错误“应用程序正常初始化(0xc0000135)失败”,我不知道这是为什么,很苦恼哇...请求高手帮帮我...
我的电脑配置是双核,2G内存,系统是xp
发表于 2011-10-15 20:19:57 | 显示全部楼层
呵呵,我也遇到这种问题了,不知道什么原因,我先用单核的运行导入设置之后,然后导出,在用并行的打开就没有问题了
 楼主| 发表于 2011-10-18 08:29:38 | 显示全部楼层
回复 2# 风流宁少 的帖子
我的设置是在单核里面进行的啊~~~还是有问题。。。哎~
发表于 2011-10-18 09:12:35 | 显示全部楼层
不需要这么复杂吧,你fluent哪个版本?
 楼主| 发表于 2011-10-19 14:44:22 | 显示全部楼层
回复 4# 浪子轻狂 的帖子
看来您有高招,可否告知于我呢?我的fluent是6.3的。
发表于 2011-10-20 09:54:43 | 显示全部楼层
右键单击fluent图标,属性,目标对话框的……-r6.3.26后面,空格-t2,确定。
重新运行fluent就可以并行了。
 楼主| 发表于 2011-10-20 10:28:44 | 显示全部楼层
回复 6# 浪子轻狂 的帖子
报告:不行啊~一旦加了空格-t2后就彻底不能运行fluent了。。。怎么办?
发表于 2012-12-6 17:48:18 | 显示全部楼层
也许你说的对,但只是一部分,琼斯家族的账我会算,说我小气也好,不讲道理也好,我的东西不予许别人乱用,而且我早就看西安白癜风他们不爽了,这次正好有这个机会。这次不管紫晶她怎么说,我一定会让琼斯家族倒霉。”蓝枫对于一些事实他不会否认,但有些事他该怎么做还是会怎么做,就算他当紫晶是自己人,还是会做他认为该做的事情。
