查看: 1987|回复: 0
gambit划分复杂网格时经常遇到下面问题,怎么解决啊
发表于 2011-10-21 08:14:50 | 显示全部楼层 |阅读模式
1.check the skewnesses of your face meshes and maksure that face mesh size are not too large in areas of small gaps.
2.an incomplet mesh may have been generated, you can modify this behaviour by changing the value of default"MESH .TRIMESH.MAX-FACES"
3.a default(unspecified) boundary entity was created
4.a default(unspecified) continuum entity was created
