查看: 1928|回复: 1
error: the number of edge points is specified as 0 on line 31
发表于 2011-10-24 17:08:33 | 显示全部楼层 |阅读模式
各位好,这是做的tur文件,能不能帮我看一下问题出在哪里,反正导入gambit之后就出现标题中的错误提示。谢谢了
/ File Version
1 3 1
/ Rotational Axis
/ Coordinate Type
/ Hub edge points
76500   0  480
/ Shroud Edge Points
76660    0 480
/ Tip Clearance Edge Points
/ Number of Blades
/ Number of Profiles
/ Number of Edges per Profile Side
/ Profile Edge Continuity
2 2 1 2
/Section (# 1)
/ suction side
10
76500   0.4404  0.0579
76500   0.4584  0.0507
76500   0.4930  0.0368
76500   0.5428  0.0224
76500   0.5916  0.0116
76500   0.6370  0.0046
76500   0.6884  0.0002
76500   0.7404  -0.0006
76500   0.8000  0.0033
76500   0.8558  0.0116
66
76500   0.8558  0.0116
76500   0.9139  0.0250
76500   0.9694  0.0426
76500   1.0254  0.0658
76500   1.0768  0.0924
76500   1.1234  0.1207
76500   1.1710  0.1566
76500   1.1989  0.1776
76500   1.2642  0.2446
76500   1.2279  0.2068
76500   1.2654  0.2461
76500   1.2815  0.2661
76500   1.3069  0.2988
76500   1.3256  0.3266
76500   1.3356  0.3428
76500   1.3400  0.3500
76500  3.14   3.55
76500  4.91   7.11
76500  6.45  10.66
76500  7.81  14.21
76500  8.98  17.76
76500  9.93  21.31
76500  10.61 24.86
76500  11.06 28.42
76500  11.28 31.97
76500  11.33 35.52
76500  11.22 39.07
76500  10.90 42.63
76500  10.40 46.17
76500  9.76  49.73
76500  9.01  53.28
76500  8.16  56.83
76500  7.25  60.38
76500  6.29  63.94
76500  5.31  67.49
76500  4.32  71.04
76500  3.33  74.59
76500  2.32  78.14
76500    2.0052   79.2375
76500    1.9978   79.2614
76500    1.9802   79.3180
76500    1.9499   79.3872
76500    1.9185   79.4470
76500    1.8899   79.4955
76500    1.8582   79.5424
76500    1.8224   79.5891
76500    1.7884   79.6288
76500    1.7507   79.6681
76500    1.7124   79.7042
76500    1.6698   79.7401
76500    1.6207   79.7769
76500    1.5648   79.8133
76500    1.5086   79.8445
76500    1.4560   79.8696
76500    1.4002   79.8927
76500    1.3381   79.9137
76500    1.2680   79.9319
76500    1.1966   79.9452
76500    1.1251   79.9528
76500    1.0546   79.9554
76500    0.9852   79.9531
76500    0.9184   79.9461
76500    0.8548   79.9350
76500    0.7994   79.9221
76500    0.7636   79.9111
76500    0.7478   79.9062
/ presure side
10
76500  0.4404   0.0579
76500  0.4249   0.0649
76500  0.3938   0.0789
76500  0.3514   0.1029
76500  0.3097   0.1299
76500  0.2697   0.1601
76500  0.2330   0.1922
76500  0.1993   0.2257
76500  0.1696   0.2592
76500  0.1390   0.2986
65
76500  0.1390   0.2986
76500  0.1122   0.3386
76500  0.0866   0.3834
76500  0.0669   0.4238
76500  0.0516   0.4613
76500  0.0388   0.4970
76500  0.0274   0.5358
76500  0.0175   0.5785
76500  0.0112   0.6158
76500  0.0072   0.6504
76500  0.0048   0.6822
76500  0.0038   0.7191
76500  0.0047   0.7554
76500  0.0077   0.7929
76500  0.0120   0.8271
76500  0.0176   0.8584
76500  0.0235   0.8856
76500  0.0278   0.9016
76500  0.0300   0.9100
76500  0.71    3.55
76500  1.62    7.12
76500  2.48   10.66
76500  3.31   14.21
76500  4.08   17.76
76500  4.78   21.31
76500  5.28   24.86
76500  5.60   28.42
76500  5.74   31.97
76500  5.74   35.52
76500  5.63   39.07
76500  5.47   42.63
76500  5.30   46.17
76500  5.07   49.73
76500  4.82   53.28
76500  4.50   56.83
76500  4.11   60.38
76500  3.63   63.94
76500  3.06   67.49
76500  2.34   71.04
76500  1.42   74.59
76500  0.30   78.14
76500   0.1232     78.6263
76500   0.1144     78.6525
76500   0.0943     78.7123
76500   0.0754     78.8026
76500   0.0640     78.9015
76500   0.0626     78.9890
76500   0.0689     79.0774
76500   0.0820     79.1624
76500   0.1052     79.2541
76500   0.1358     79.3392
76500   0.1708     79.4148
76500   0.2108     79.4864
76500   0.2537     79.5497
76500   0.3035     79.6121
76500   0.3562     79.6690
76500   0.4114     79.7191
76500   0.4611     79.7583
76500   0.5052     79.7895
76500   0.5559     79.8212
76500   0.6085     79.8496
76500   0.6560     79.8716
76500   0.7006     79.8900
76500   0.7296     79.8999
/Section (# 2)
/ suction side
10
76660   0.4404  0.0579
76660   0.4584  0.0507
76660   0.4930  0.0368
76660   0.5428  0.0224
76660   0.5916  0.0116
76660   0.6370  0.0046
76660   0.6884  0.0002
76660   0.7404  -0.0006
76660   0.8000  0.0033
76660   0.8558  0.0116
66
76660   0.8558  0.0116
76660   0.9139  0.0250
76660   0.9694  0.0426
76660   1.0254  0.0658
76660   1.0768  0.0924
76660   1.1234  0.1207
76660   1.1710  0.1566
76660   1.1989  0.1776
76660   1.2642  0.2446
76660   1.2279  0.2068
76660   1.2654  0.2461
76660   1.2815  0.2661
76660   1.3069  0.2988
76660   1.3256  0.3266
76660   1.3356  0.3428
76660   1.3400  0.3500
76660  3.14   3.55
76660  4.91   7.11
76660  6.45  10.66
76660  7.81  14.21
76660  8.98  17.76
76660  9.93  21.31
76660  10.61 24.86
76660  11.06 28.42
76660  11.28 31.97
76660  11.33 35.52
76660  11.22 39.07
76660  10.90 42.63
76660  10.40 46.17
76660  9.76  49.73
76660  9.01  53.28
76660  8.16  56.83
76660  7.25  60.38
76660  6.29  63.94
76660  5.31  67.49
76660  4.32  71.04
76660  3.33  74.59
76660  2.32  78.14
76660    2.0052   79.2375
76660    1.9978   79.2614
76660    1.9802   79.3180
76660    1.9499   79.3872
76660    1.9185   79.4470
76660    1.8899   79.4955
76660    1.8582   79.5424
76660    1.8224   79.5891
76660    1.7884   79.6288
76660    1.7507   79.6681
76660    1.7124   79.7042
76660    1.6698   79.7401
76660    1.6207   79.7769
76660    1.5648   79.8133
76660    1.5086   79.8445
76660    1.4560   79.8696
76660    1.4002   79.8927
76660    1.3381   79.9137
76660    1.2680   79.9319
76660    1.1966   79.9452
76660    1.1251   79.9528
76660    1.0546   79.9554
76660    0.9852   79.9531
76660    0.9184   79.9461
76660    0.8548   79.9350
76660    0.7994   79.9221
76660    0.7636   79.9111
76660    0.7478   79.9062
/ pressure side
10
76660  0.4404   0.0579
76660  0.4249   0.0649
76660  0.3938   0.0789
76660  0.3514   0.1029
76660  0.3097   0.1299
76660  0.2697   0.1601
76660  0.2330   0.1922
76660  0.1993   0.2257
76660  0.1696   0.2592
76660  0.1390   0.2986
65
76660  0.1390   0.2986
76660  0.1122   0.3386
76660  0.0866   0.3834
76660  0.0669   0.4238
76660  0.0516   0.4613
76660  0.0388   0.4970
76660  0.0274   0.5358
76660  0.0175   0.5785
76660  0.0112   0.6158
76660  0.0072   0.6504
76660  0.0048   0.6822
76660  0.0038   0.7191
76660  0.0047   0.7554
76660  0.0077   0.7929
76660  0.0120   0.8271
76660  0.0176   0.8584
76660  0.0235   0.8856
76660  0.0278   0.9016
76660  0.0300   0.9100
76660  0.71    3.55
76660  1.62    7.12
76660  2.48   10.66
76660  3.31   14.21
76660  4.08   17.76
76660  4.78   21.31
76660  5.28   24.86
76660  5.60   28.42
76660  5.74   31.97
76660  5.74   35.52
76660  5.63   39.07
76660  5.47   42.63
76660  5.30   46.17
76660  5.07   49.73
76660  4.82   53.28
76660  4.50   56.83
76660  4.11   60.38
76660  3.63   63.94
76660  3.06   67.49
76660  2.34   71.04
76660  1.42   74.59
76660  0.30   78.14
76660   0.1232     78.6263
76660   0.1144     78.6525
76660   0.0943     78.7123
76660   0.0754     78.8026
76660   0.0640     78.9015
76660   0.0626     78.9890
76660   0.0689     79.0774
76660   0.0820     79.1624
76660   0.1052     79.2541
76660   0.1358     79.3392
76660   0.1708     79.4148
76660   0.2108     79.4864
76660   0.2537     79.5497
76660   0.3035     79.6121
76660   0.3562     79.6690
76660   0.4114     79.7191
76660   0.4611     79.7583
76660   0.5052     79.7895
76660   0.5559     79.8212
76660   0.6085     79.8496
76660   0.6560     79.8716
76660   0.7006     79.8900
76660   0.7296     79.8999
 楼主| 发表于 2011-10-24 22:39:46 | 显示全部楼层
解决了!
呵呵,分享一下错误的原因。
在写profile edge continuty的时候 ,要对profile上一侧的所有点都指定连续性值,包括前缘点和尾缘点。因此,当你指定profile单侧有n条边的时候 ,你需要给定n+1个连续性值(0,1,2)
0代表连续但不可导;
1代表连续且了阶可导;
2代表连续且二阶可导;
