查看: 2525|回复: 0
roughness constant粗糙常数是什么含义?
发表于 2011-11-1 17:20:44 | 显示全部楼层 |阅读模式
请问在k-e模型中壁面条件的roughness constant是什么含义?
帮助文件这么说明
The default roughness constant was determined so that, when used with   -   turbulence models, it reproduces Nikuradse’s resistance data for pipes roughened with tightly-packed, uniform sand-grain roughness. You may need to adjust the roughness constant when the roughness you want to model departs much from uniform sand-grain.
我看不懂,有高手给解释一下吗,万分感谢!
