查看: 4252|回复: 1
怎么定义这个方程:Uxx-a^2Ut+A*exp(-a*x)=0
发表于 2011-11-15 22:04:21 | 显示全部楼层 |阅读模式
先在CFD on line上发的帖,直接粘过来了:
hello every one, i need your help now.
i'm tring to solve this PDE:Uxx-a^2Ut+A*exp(-a*x)=0 with openFoam,
after copying the solver "laplacianFoam"to my own directory and changing it to myLaplacianFoam, i add two lines in the "main" function in the myLaplacianFoam.c like this:
     volVectorField centers = T.mesh().C();
     volScalarField x = (centers&vector(1,0,0));
then define the equation :
         -fvm::ddt(sqr(a),T) - fvm::laplacian(T) == -A*exp(-a*x);
the parameters A and a  are defined in creatFiled.H and in transportProperties dictionary file within the case directory.
when i try to use this solver,   the error echoed :
Argument of trancendental function not dimensionless
how could i deal with this  problem?
shoul i make the argument in the exp() function dimensioniess or define the A*exp(-a*x) as a volScalarField "f" in createFiled.H,and give "f" the original and boundary value in the case directory when i need to run the solver?
by the way ,if i want to utilize openFoam to solve some typical PDEs,where can i find the reference source?
thanks for your attention.
 楼主| 发表于 2011-11-16 10:40:41 | 显示全部楼层
不能沉阿。。。。
