查看: 2586|回复: 4
ansys workbench 12.1 fluent 网格检查出错!
发表于 2011-11-17 20:52:49 | 显示全部楼层 |阅读模式
Domain Extents:
   x-coordinate: min (m) = -1.625000e-001, max (m) = 1.302034e-001
   y-coordinate: min (m) = -1.425202e-001, max (m) = 2.300000e-001
   z-coordinate: min (m) = -1.400000e-002, max (m) = 9.800000e-002
Volume statistics:
   minimum volume (m3): 1.718326e-011
   maximum volume (m3): 2.417885e-007
     total volume (m3): 1.860582e-003
Face area statistics:
   minimum face area (m2): 5.448650e-008
   maximum face area (m2): 5.740002e-005
Checking number of nodes per cell.
Checking number of faces per cell.
Checking thread pointers.
Checking number of cells per face.
Checking face cells.
Checking cell connectivity.
Checking bridge faces.
Checking right-handed cells.
Checking face handedness.
Checking face node order.
Checking closed cells.
Checking contact points.
Checking element type consistency.
Checking boundary types.
Checking face pairs.
Checking wall distance.
Checking node count.
Checking nosolve cell count.
Checking nosolve face count.
Checking face children.
Checking cell children.
WARNING: Unassigned interface zone detected for interface 10
WARNING: Unassigned interface zone detected for interface 11
Checking storage.
Done.
WARNING: Mesh check failed.
有谁知道这是怎么错了的?新手看不明白啊!
发表于 2011-11-18 09:10:49 | 显示全部楼层
网格出问题,那就重新画网格了。没有其他办法。当然,因为某些对称模型,导致的网格检测出错,更改一下fluent的模型即可。
发表于 2011-11-18 09:19:44 | 显示全部楼层
应该不是问题吧,把那两个WARNING解决了就行了。你用了interface,读入网格后先把interface设定好。
发表于 2011-11-19 09:18:19 | 显示全部楼层
谢谢,问题已解决
发表于 2012-12-17 17:16:35 | 显示全部楼层
请问你这个问题是怎么解决的。利用ansys workbench。我总是解决不了啊。
