查看: 5572|回复: 3
finite-rate/eddy dissipation与EDC模型的区别
发表于 2011-11-24 10:15:37 | 显示全部楼层 |阅读模式
finite-rate/eddy dissipation与EDC模型的区别,一直搞不懂,请各位赐教
发表于 2011-11-24 14:11:30 | 显示全部楼层
finite-rate/eddy dissipation:The source term for species “i” is the sum of sources in all participating reactions, the term of species i in reacktion k is the smaller between Arrhenius rate and eddy breakup rate;unreliable when Da~1;can not predict intermediate species, i.e., can not use detailed kinetics; widely used because of simplicity and physical based.
EDC: detailed chemistry model like laminar finite rate model, but can predict turbulence-chemistry interaction. Computationally expensive; assumes that reaction occurs in small turbulent structures; only used when the assumption of fast chemistry is invalid.
 楼主| 发表于 2011-11-25 15:11:49 | 显示全部楼层
回复 2# yulei97 的帖子
谢谢
发表于 2011-11-27 20:18:14 | 显示全部楼层
那pdf和edc的区别呢,我也搞不清楚,而且不是PDF的扩展模型也可以计算化学反应吗,也可以定义化学反应方程吗,到的PDF和edc的优缺点在哪
