查看: 4752|回复: 1
FASTRAN错误,计算中断
发表于 2011-12-5 22:52:39 | 显示全部楼层 |阅读模式
各位高手,我使用FASTRAN做流体计算,经常会遇到错误而中断。错误信息有两类,不定时出现:
(1)OUTPUT文件里面
[ERROR]: (pforce_szone) Error opening residual file ***.FORCE
---- Program Execution due to Error.
或
ERROR]: (wmaxresid) Error opening residual file ***.RSL
或
[ERROR]: (write-monitor) Error opening monitor-point output file ***.MON.00001
(2)弹出错误窗口Visual Fortran run-time error. 内容如下:
forrtl:severe (30): open failure, unit 2, file
E:\***\***.RZ
Image   PC   Routine   Line   Source
libifcoremd.dll     1003D76E   Unknown   Unknown    Unknown
Stack trace terminated abnormally.
我用的ESI-FASTRAN 2008.0,破解的,求用过fastran的高人指点。
发表于 2012-3-14 09:08:07 | 显示全部楼层
顶下,我最近也遇到同样的问题。错误后点continue仍可以继续算
