查看: 2966|回复: 0
并行计算
发表于 2012-2-9 13:37:37 | 显示全部楼层 |阅读模式
用cfx并行计算时(hp mpi),一开始出现如下信息:
  Memory Allocated for Run  (Actual usage may be less)        |
  Data Type      Kwords  Words/Node  Words/Elem      Kbytes Bytes/Node
  Real           1269.6      122.80       25.46      4959.5     491.20
  Integer        2234.5      216.12       44.80      8728.6     864.50
  Character      2991.6      289.35       59.98      2921.5     289.35
  Logical          65.0        6.29        1.30       253.9      25.15
  Double          299.8       28.99        6.01      2341.9     231.95
Details of error:-
Error detected by routine MAKDAT
Illegal data area length CDANAM =  KVxPairCs CDTYPE =  INTR ISIZE =  0
CRESLT = SIZE
Current Directory : /FLOW/MESH/TSTEP0/CLOOP0/ZIF1
| ERROR #001100279 has occurred in subroutine ErrAction.             |
| Stopped in routine MEMERR                                          |
|                An error has occurred in cfx5solve:                 |
| The ANSYS CFX partitioner exited with return code 1.               |
This run of the ANSYS CFX Solver has finished.
这是怎么回事?谢了
