查看: 2587|回复: 2
请教:fluent计算出现问题!
发表于 2007-4-9 10:19:17 | 显示全部楼层 |阅读模式
我在设置好参数后开始计算是程序老是出现以下内容,然后说出现错误,请问那位高手可以帮我看看,是什么问题.谢谢!
Updating solution at time levels N and N-1.
done.
  iter continuity x-velocity y-velocity z-velocity     energy          k    epsilon     time/iter
divergence detected - temporarily reducing Courant number to 0.5
and trying again...
divergence detected - temporarily reducing Courant number to 0.05
and trying again...
divergence detected - temporarily reducing Courant number to 0.005
and trying again...
divergence detected - temporarily reducing Courant number to 0.0005
and trying again...
divergence detected - temporarily reducing Courant number to 5e-005
and trying again...
Error: Internal error at line 914 in file ';..\..\src\rp_mstage.c';.
divergence detected in AMG solver
Error Object: ()
发表于 2007-4-10 09:41:50 | 显示全部楼层
请教:fluent计算出现问题!
Maybe you can start calculating with the courant number of 0.01, and then  add it gradually.
发表于 2007-4-10 19:59:26 | 显示全部楼层
请教:fluent计算出现问题!
courant number 到5E-5了都没用更别说0.01了.   通常是网格质量不佳或边界条件起始值太大.
