查看: 2248|回复: 2
UDF求助
发表于 2012-3-27 15:53:32 | 显示全部楼层 |阅读模式
写了一个UDF,帮忙鉴定下是不是有什么问题啊,不能编译啊,
#include<stdio.h>
#include"udf.h"
DEFINE_CG_MOTION(name,dt,moving_wall_vel,omega,time,dtime)
  if(time>=0&&time<=1)
     moving_wall_vel[0]=0.03-0.03*cos(3.141593*time);
  else
     moving_wall_vel[0]=0.06;
发表于 2012-3-27 16:28:50 | 显示全部楼层
没有问题的,可能是你vc平台没装好。
另外就是if(time>=0&&time<=1)没必要这么写,if(time<=1.)就行了。
发表于 2012-3-30 15:35:42 | 显示全部楼层
回复 2# 浪子轻狂 的帖子
你好,我现在单机采用的udf代码如下:
#include "udf.h"
#define pi 4.*atan(1.)
#define diam2 3.e-4
DEFINE_EXCHANGE_PROPERTY(custom_drag3,cell,mix_thread,s_col,f_col)
Thread *thread_g, *thread_s;
real x_vel_g, x_vel_s, y_vel_g, y_vel_s, abs_v, slip_x, slip_y,
      rho_g, rho_s, mu_g, reyp, afac,
      bfac, void_g, vfac, fdrgs, taup, k_g_s;
/* find the threads for the gas (primary) */
/* and solids (secondary phases)          */
thread_g = THREAD_SUB_THREAD(mix_thread, s_col);/* gas phase  */
thread_s = THREAD_SUB_THREAD(mix_thread, f_col);/* solid phase*/
/* find phase velocities and properties*/
x_vel_g = C_U(cell, thread_g);
y_vel_g = C_V(cell, thread_g);
x_vel_s = C_U(cell, thread_s);
y_vel_s = C_V(cell, thread_s);
slip_x = x_vel_g - x_vel_s;
slip_y = y_vel_g - y_vel_s;
rho_g = C_R(cell, thread_g);
rho_s = C_R(cell, thread_s);
mu_g = C_MU_L(cell, thread_g);
/*compute slip*/
abs_v = sqrt(slip_x*slip_x + slip_y*slip_y);
/*compute Reynold's number*/
reyp = rho_g*abs_v*diam2/mu_g;
/* compute particle relaxation time */
taup = rho_s*diam2*diam2/18./mu_g;
void_g = C_VOF(cell, thread_g);/* gas vol frac*/
/*compute drag and return drag coeff, k_g_s*/
afac = pow(void_g,4.14);
if(void_g<=0.85)
  bfac = 0.281632*pow(void_g, 1.28);
else
  bfac = pow(void_g, 9.076960);
vfac = 0.5*(afac-0.06*reyp+sqrt(0.0036*reyp*reyp+0.12*reyp*(2.*bfac-
              afac)+afac*afac));
fdrgs = void_g*(pow((0.63*sqrt(reyp)/
                            vfac+4.8*sqrt(vfac)/vfac),2))/24.0;
k_g_s = (1.-void_g)*rho_s*fdrgs/taup;
return k_g_s;
现在想要到服务器上并行计算,要加一些语句,具体在哪儿加呢?
