查看: 2929|回复: 1
fluent噪声的dpdt RMS 是神马??
发表于 2012-4-1 10:07:28 | 显示全部楼层 |阅读模式
各位看官,请问在fluent噪声里面,display>contours>avoustics>surface dpdt RMS 的 dpdt RMS 是神马东西?
 楼主| 发表于 2012-4-1 10:39:43 | 显示全部楼层
回复 1# dongpo05 的帖子
Ok,自己解决吧。
基本理解
help里面介绍了:
The RMS value of the static pressure time derivative ( ) is available for postprocessing only on wall surfaces, which are at the same time sources of sound, when the FW-H acoustics model is used.
