查看: 1680|回复: 0
[求助]fluent安装时,有问题,那位好心人帮忙啊
发表于 2007-4-13 10:35:18 | 显示全部楼层 |阅读模式
Locating Exceed installation ...
Launching Exceed 12 ...
Starting C:\Fluent.Inc\gambit2.3.16\ntx86\gambit.exe -device open -id default_id1460 -new  ...
*** Server node is down or not responding
See the system adminstrator about starting the server, or
make sure the you';re referring to the right host (see LM_LICENSE_FILE)
Feature:       gambit
Hostname:      gg
License path:  C:\Fluent.Inc\license\ntx86\..\license.dat
FLEXlm error:  -96,7.  System Error: 11001 "WinSock: Host not found (HOST_NOT_FOUND)"
available at "www.macrovision.com".
Feature:       gambit-addon
Hostname:      gg
FATAL ERROR: Could not obtain valid license authorization.
Total of 0.00 cpu second(s), 101792 maximum memory.
安装后,运行时会提示这个,为什么阿,我该怎么办?
