查看: 1877|回复: 0
udf单核计算可以,双核编译正确,计算不能进行,怎么回事啊
发表于 2012-4-17 09:54:00 | 显示全部楼层 |阅读模式
前面定义这个宏,DEFINE_EXCHANGE_PROPERTY(custom_drag2, cell, mix_thread, s_col, f_col)里面计算k_g_s_1, k_g_s_2,后面想按坐标分段取值,这是我的代码:
#if !RP_HOST                                                   /* 97*/
             begin_c_loop(c,t)
         Thread *t;
        cell_t c;
         C_CENTROID(x,c,t);
               z=x[2];
         if(z<1.6)
          k_g_s=k_g_s_2;
        else
             if((z>=1.6)&&(z<=1.88))
k_g_s=(-25*z/7+47/7)*k_g_s_2+(25*z/7-40/7)*k_g_s_1;
           else
                 k_g_s=k_g_s_1;
  end_c_loop(c,t)
    #endif
        return k_g_s;
链接到case之后,计算一步就出现以下错误:unable to read the cmd header on the pmi context, Undefined dynamic error code.
999999 (..\..\src\mpsystem.c@1123): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 4 bytes: No such file or directory
received suspend command for a pmi context that doesn't exist: unmatched id = 0
received kill command for a pmi context that doesn't exist: unmatched id = 0
job aborted:
rank: node: exit code[: error message]
0: why: -1073741819: process 0 exited without calling finalize
1: why: -1073741819: process 1 exited without calling finalize
