查看: 3100|回复: 0
请问Global courant number 的问题
发表于 2012-5-12 17:28:19 | 显示全部楼层 |阅读模式
这是计算了一个时间步长就报错
Updating solution at time level N...
Global Courant Number : 584858812830.00
Error: Global courant number is greater than 250.0. The
velocity field is probably diverging. Please check the solution
and reduce the time-step if necessary.
Error Object: ()
我的是VOF+融合凝固模型,步长为0.002,求达人解答,这是什么原因造成的??
