查看: 2805|回复: 3
求助:Fluent6.3与ansys13.0的check问题
发表于 2012-5-29 14:54:00 | 显示全部楼层 |阅读模式
用Fluent6.3check的时候没问题,但是用ansys13.0 check的时候会有warning,这是为什么?ansys13.0对网格质量要求更高?
WARNING: The mesh contains high aspect ratio quadrilateral,
         hexahedral, or polyhedral cells.
         The default algorithm used to compute the wall
         distance required by the turbulence models might
         produce wrong results in these cells.
         Please inspect the wall distance by displaying the
         contours of the 'Cell Wall Distance' at the
         boundaries. If you observe any irregularities we
         recommend the use of an alternative algorithm to
         correct the wall distance.
         Please select /solve/initialize/repair-wall-distance
         using the text user interface to switch to the
         alternative algorithm.
发表于 2012-5-29 22:00:53 | 显示全部楼层
6.3和13check mesh的默认标准不一样
发表于 2012-5-30 09:28:15 | 显示全部楼层
支持正版情况下,分析软件用最新版本较优
发表于 2012-6-13 14:56:30 | 显示全部楼层
我用的14.0,,,也出现过这种情况,,,纵横比大了。。。。
