查看: 1915|回复: 0
Fluent中流固耦合传热问题
发表于 2012-6-10 10:44:45 | 显示全部楼层 |阅读模式
To couple the two sides of the wall, select the Coupled option under Thermal Conditions. (This option will appear in the Wall panel only when the wall is a two-sided wall.) No additional thermal boundary conditions are required, because the solver will calculate heat transfer directly from the solution in the adjacent cells.
他说是“不需要给定额外的热边界条件,因为求解器会直接从临近的单元计算热传导”。
可是,Fluent是怎么计算的呢?原理是什么,有哪位大侠能告诉我吗?
真心求指教啊
