查看: 1692|回复: 0
数值水池问题
发表于 2012-7-2 08:03:27 | 显示全部楼层 |阅读模式
采用FLUENT模拟数值水池时报错:ST_Create_Store: out of memory.unable to read the cmd header on the pmi context, Undefined dynamic error code.
999999 (..\..\src\mpsystem.c@1123): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 8 bytes: No such file or directory
job aborted:
rank: node: exit code[: error message]
0: user4: 123
1: user4: -1073741819: process 1 exited without calling finalize
The Parallel FLUENT process could not be started.
那位高人指点一下。
