查看: 3059|回复: 1
源相造波不收敛啊~~~~~~
发表于 2012-9-29 09:06:29 | 显示全部楼层 |阅读模式
数值波浪水槽,用源相造波,可以每次都计算到500时间步的时候就出现不收敛了,具体如下:
Flow time = 1.3000001, time step = 650
9350 more time steps
Updating solution at time level N...
Global Courant Number : 3456251.71
Error: Global courant number is greater than 250.0. The
velocity field is probably diverging. Please check the solution
and reduce the time-step if necessary.
Error Object: ()
求好心人指导下!!!
发表于 2015-4-2 20:19:13 | 显示全部楼层
你好,我也正在做源造波,能把你的UDF文件发我一份吗,我参考参考,我是刚学的什么都不会。1085569407@qq.com谢谢了
