查看: 3540|回复: 5
请教关于FLuent计算时间问题
发表于 2007-6-1 10:46:58 | 显示全部楼层 |阅读模式
以下是我的Fluent计算信息,请问我的Fluent计算所需时间怎么算呢?
难道是所有最大的时间相加么?可是我自己用手表计时间才十三四秒钟,差的太多了,清高手指教!!先谢谢了
  iter continuity x-velocity y-velocity     energy     time/iter
     1 1.0000e+00 3.5125e-01 8.4946e-08 5.0010e-08  0:00:00  499
     2 1.0000e+00 2.3478e-01 2.1371e-01 5.8519e-08  0:08:18  498
     3 8.9112e-01 1.0938e-01 7.6781e-02 5.7325e-08  0:06:38  497
     4 1.0000e+00 6.9259e-02 4.9517e-02 5.2115e-08  0:05:17  496
reversed flow in 23 faces on pressure-inlet 5.
     5 8.3335e-01 5.2246e-02 5.4127e-02 2.2390e-07  0:04:13  495
reversed flow in 21 faces on pressure-inlet 5.
     6 6.2569e-01 4.5148e-02 7.9020e-02 1.9400e-07  0:03:22  494
reversed flow in 51 faces on pressure-inlet 5.
     7 5.2034e-01 3.9797e-02 9.0528e-02 1.1093e-07  0:02:42  493
reversed flow in 42 faces on pressure-inlet 5.
     8 4.8762e-01 3.7388e-02 1.0177e-01 1.0616e-07  0:02:09  492
reversed flow in 47 faces on pressure-inlet 5.
     9 4.0235e-01 3.3012e-02 1.1105e-01 1.0156e-07  0:01:43  491
reversed flow in 25 faces on pressure-inlet 5.
    10 4.4763e-01 3.2676e-02 1.1929e-01 8.0398e-08  0:01:22  490
reversed flow in 27 faces on pressure-inlet 5.
    11 3.5280e-01 3.2023e-02 1.1699e-01 7.6023e-08  0:01:06  489
reversed flow in 20 faces on pressure-inlet 5.
    12 3.0481e-01 3.4940e-02 1.2620e-01 6.1570e-08  0:00:52  488
    13 2.4768e-01 3.4408e-02 1.3006e-01 7.5849e-08  0:00:42  487
    14 1.9362e-01 3.5420e-02 1.3577e-01 8.3289e-08  0:00:33  486
reversed flow in 34 faces on pressure-inlet 5.
    15 1.6765e-01 3.7355e-02 1.5004e-01 7.4099e-08  0:00:27  485
reversed flow in 1 faces on pressure-outlet 4.
reversed flow in 32 faces on pressure-inlet 5.
    16 1.5010e-01 3.9721e-02 1.7167e-01 1.0463e-07  0:01:58  484
reversed flow in 75 faces on pressure-inlet 5.
    17 1.3142e-01 3.9328e-02 1.9184e-01 1.0462e-07  0:01:34  483
reversed flow in 76 faces on pressure-inlet 5.
    18 1.1780e-01 4.5447e-02 2.2148e-01 3.8580e-07  0:01:15  482
reversed flow in 2 faces on pressure-outlet 4.
reversed flow in 14 faces on pressure-inlet 5.
    19 1.1092e-01 5.0730e-02 2.8980e-01 7.2557e-07  0:01:00  481
reversed flow in 63 faces on pressure-inlet 5.
    20 9.8035e-02 3.3867e-02 2.8474e-01 5.4201e-07  0:00:48  480
reversed flow in 59 faces on pressure-inlet 5.
    21 8.8756e-02 3.3614e-02 2.9783e-01 6.7451e-07  0:00:38  479
reversed flow in 49 faces on pressure-inlet 5.
    22 8.0430e-02 2.4876e-02 2.6646e-01 8.6374e-07  0:00:31  478
reversed flow in 69 faces on pressure-inlet 5.
    23 7.4278e-02 1.7566e-02 2.1922e-01 6.3529e-07  0:00:24  477
reversed flow in 40 faces on pressure-inlet 5.
    24 6.6788e-02 1.3066e-02 1.9423e-01 6.6922e-07  0:00:19  476
reversed flow in 30 faces on pressure-inlet 5.
    25 6.1525e-02 1.0431e-02 1.6907e-01 4.4190e-07  0:00:16  475
    26 5.6355e-02 8.1591e-03 1.4961e-01 5.2552e-07  0:00:12  474
reversed flow in 17 faces on pressure-inlet 5.
    27 5.2740e-02 7.1515e-03 1.3844e-01 2.5186e-07  0:00:10  473
reversed flow in 16 faces on pressure-inlet 5.
    28 4.9220e-02 5.5659e-03 1.3273e-01 1.1296e-07  0:00:08  472
    29 4.6425e-02 4.4246e-03 1.2952e-01 1.1895e-07  0:00:06  471
reversed flow in 13 faces on pressure-inlet 5.
    30 4.4524e-02 3.6640e-03 1.2250e-01 9.7955e-08  0:00:05  470
reversed flow in 12 faces on pressure-inlet 5.
    31 4.2552e-02 2.9697e-03 1.1447e-01 9.8120e-08  0:00:04  469
reversed flow in 7 faces on pressure-inlet 5.
    32 4.0100e-02 2.5277e-03 1.0477e-01 8.9811e-08  0:00:03  468
reversed flow in 5 faces on pressure-inlet 5.
    33 3.7614e-02 2.1928e-03 9.5791e-02 9.2866e-08  0:01:36  467
reversed flow in 4 faces on pressure-inlet 5.
    34 3.5722e-02 2.1355e-03 8.9992e-02 9.9653e-08  0:01:17  466
    35 3.4458e-02 2.1082e-03 9.2342e-02 1.0315e-07  0:01:01  465
reversed flow in 3 faces on pressure-inlet 5.
    36 3.2686e-02 1.8587e-03 8.1953e-02 1.0119e-07  0:00:49  464
    37 3.1102e-02 1.9768e-03 7.6399e-02 9.7172e-08  0:00:39  463
reversed flow in 2 faces on pressure-inlet 5.
    38 2.9862e-02 1.9474e-03 7.2696e-02 8.7560e-08  0:00:31  462
    39 2.8830e-02 1.7967e-03 7.2053e-02 8.3283e-08  0:00:25  461
reversed flow in 1 faces on pressure-inlet 5.
    40 2.7741e-02 1.7315e-03 6.3806e-02 7.8322e-08  0:00:20  460
    41 2.6679e-02 1.7046e-03 5.8880e-02 7.5386e-08  0:00:16  459
    42 2.5585e-02 1.6270e-03 5.8964e-02 7.0885e-08  0:00:13  458
    43 2.4505e-02 1.5040e-03 5.5896e-02 6.7601e-08  0:00:10  457
    44 2.3523e-02 1.4715e-03 5.1725e-02 6.5068e-08  0:00:08  456
    45 2.2642e-02 1.4717e-03 4.8778e-02 6.2292e-08  0:00:06  455
    46 2.1828e-02 1.4149e-03 4.6995e-02 5.7629e-08  0:00:05  454
    47 2.1075e-02 1.3643e-03 4.5243e-02 5.6631e-08  0:00:04  453
    48 2.0384e-02 1.3543e-03 4.2970e-02 5.6180e-08  0:00:03  452
    49 1.9714e-02 1.3632e-03 4.0612e-02 5.2510e-08  0:00:03  451
    50 1.9086e-02 1.3968e-03 3.9018e-02 5.0085e-08  0:01:32  450
    51 1.8495e-02 1.4395e-03 3.7657e-02 5.1667e-08  0:01:14  449
    52 1.7942e-02 1.4848e-03 3.6440e-02 5.0516e-08  0:00:59  448
    53 1.7435e-02 1.4935e-03 3.5365e-02 5.1038e-08  0:00:47  447
    54 1.6954e-02 1.5018e-03 3.4474e-02 5.1333e-08  0:00:37  446
    55 1.6498e-02 1.5129e-03 3.3665e-02 5.0544e-08  0:00:30  445
    56 1.6064e-02 1.5313e-03 3.2853e-02 5.0577e-08  0:00:24  444
    57 1.5642e-02 1.5565e-03 3.2125e-02 4.6871e-08  0:00:19  443
    58 1.5234e-02 1.5908e-03 3.1260e-02 4.9037e-08  0:00:15  442
    59 1.4840e-02 1.6345e-03 3.0605e-02 4.8411e-08  0:00:12  441
    60 1.4456e-02 1.6569e-03 3.0310e-02 5.0117e-08  0:00:10  440
    61 1.4078e-02 1.6602e-03 3.0174e-02 4.8686e-08  0:00:08  439
    62 1.3726e-02 1.6497e-03 3.0143e-02 4.7419e-08  0:00:06  438
    63 1.3396e-02 1.6457e-03 2.9601e-02 4.7887e-08  0:00:05  437
    64 1.3078e-02 1.6526e-03 2.8865e-02 4.6574e-08  0:00:04  436
    65 1.2766e-02 1.6645e-03 2.7956e-02 4.9332e-08  0:00:03  435
    66 1.2461e-02 1.6729e-03 2.6942e-02 4.7348e-08  0:00:02  434
    67 1.2157e-02 1.6712e-03 2.5941e-02 4.6672e-08  0:00:02  433
    68 1.1857e-02 1.6516e-03 2.5157e-02 4.6837e-08  0:00:02  432
    69 1.1566e-02 1.6251e-03 2.4645e-02 4.8678e-08  0:01:27  431
    70 1.1280e-02 1.5870e-03 2.4410e-02 4.6890e-08  0:01:10  430
    71 1.1003e-02 1.5508e-03 2.4066e-02 4.6422e-08  0:00:56  429
    72 1.0738e-02 1.5251e-03 2.3579e-02 4.5884e-08  0:00:44  428
    73 1.0480e-02 1.5125e-03 2.2855e-02 4.6629e-08  0:00:35  427
    74 1.0230e-02 1.5149e-03 2.2012e-02 4.6672e-08  0:00:28  426
    75 9.9921e-03 1.5286e-03 2.1327e-02 4.7278e-08  0:00:23  425
    76 9.7638e-03 1.5837e-03 2.0685e-02 4.8738e-08  0:00:18  424
    77 9.5431e-03 1.5975e-03 2.0101e-02 4.6148e-08  0:00:14  423
    78 9.3288e-03 1.6071e-03 1.9530e-02 4.6568e-08  0:00:11  422
    79 9.1215e-03 1.6188e-03 1.8980e-02 4.7918e-08  0:00:09  421
    80 8.9239e-03 1.6308e-03 1.8461e-02 4.7904e-08  0:00:07  420
    81 8.7341e-03 1.6415e-03 1.7956e-02 4.9003e-08  0:00:06  419
    82 8.5506e-03 1.6523e-03 1.7455e-02 4.6137e-08  0:00:05  418
    83 8.3712e-03 1.6650e-03 1.6977e-02 4.5393e-08  0:00:04  417
    84 8.1983e-03 1.6757e-03 1.6503e-02 4.5825e-08  0:00:03  416
    85 8.0321e-03 1.6860e-03 1.6048e-02 4.6275e-08  0:00:02  415
    86 7.8694e-03 1.6965e-03 1.5586e-02 4.4106e-08  0:01:25  414
    87 7.7118e-03 1.7050e-03 1.5161e-02 4.5950e-08  0:01:08  413
    88 7.5575e-03 1.6520e-03 1.4733e-02 4.7488e-08  0:00:54  412
    89 7.4059e-03 1.6523e-03 1.4371e-02 4.8050e-08  0:00:43  411
    90 7.2578e-03 1.6557e-03 1.4049e-02 4.5491e-08  0:00:34  410
    91 7.1129e-03 1.6575e-03 1.3765e-02 4.5994e-08  0:00:27  409
    92 6.9712e-03 1.6550e-03 1.3466e-02 4.6298e-08  0:00:22  408
    93 6.8323e-03 1.6580e-03 1.3189e-02 4.5446e-08  0:00:17  407
    94 6.6975e-03 1.6424e-03 1.2924e-02 4.5011e-08  0:00:14  406
    95 6.5670e-03 1.6360e-03 1.2681e-02 4.3881e-08  0:00:11  405
    96 6.4388e-03 1.6270e-03 1.2446e-02 4.4790e-08  0:00:09  404
    97 6.3129e-03 1.6153e-03 1.2212e-02 4.7406e-08  0:00:07  403
    98 6.1909e-03 1.6016e-03 1.1972e-02 4.5906e-08  0:00:06  402
    99 6.0765e-03 1.5852e-03 1.1749e-02 4.5587e-08  0:00:05  401
   100 5.9645e-03 1.5673e-03 1.1528e-02 4.5808e-08  0:00:04  400
   101 5.8545e-03 1.5500e-03 1.1301e-02 4.6226e-08  0:00:03  399
   102 5.7467e-03 1.5314e-03 1.1067e-02 4.5789e-08  0:00:02  398
   103 5.6411e-03 1.5113e-03 1.0842e-02 4.6543e-08  0:00:02  397
   104 5.5376e-03 1.4889e-03 1.0592e-02 4.6334e-08  0:00:01  396
   105 5.4383e-03 1.4708e-03 1.0335e-02 4.6079e-08  0:01:20  395
   106 5.3412e-03 1.4544e-03 1.0072e-02 4.6590e-08  0:01:04  394
   107 5.2468e-03 1.4470e-03 9.8334e-03 4.6541e-08  0:00:51  393
   108 5.1554e-03 1.3935e-03 9.6088e-03 4.6333e-08  0:00:41  392
   109 5.0650e-03 1.4359e-03 9.3418e-03 4.6462e-08  0:00:33  391
   110 4.9766e-03 1.4173e-03 9.1159e-03 4.7163e-08  0:00:26  390
   111 4.8899e-03 1.3934e-03 8.8970e-03 4.6621e-08  0:00:21  389
   112 4.8050e-03 1.3697e-03 8.6916e-03 4.7292e-08  0:00:17  388
   113 4.7218e-03 1.2620e-03 8.5202e-03 4.5360e-08  0:00:13  387
   114 4.6400e-03 1.2438e-03 8.3293e-03 4.6994e-08  0:00:11  386
   115 4.5598e-03 1.2365e-03 8.1396e-03 4.6906e-08  0:00:08  385
   116 4.4813e-03 1.2286e-03 7.9446e-03 4.4115e-08  0:00:07  384
   117 4.4047e-03 1.3015e-03 7.7407e-03 4.6307e-08  0:00:05  383
   118 4.3299e-03 1.2795e-03 7.5608e-03 4.7581e-08  0:00:04  382
   119 4.2566e-03 1.2514e-03 7.4044e-03 4.8397e-08  0:00:03  381
   120 4.1858e-03 1.2246e-03 7.2519e-03 4.6529e-08  0:00:03  380
   121 4.1176e-03 1.1993e-03 7.1029e-03 4.7393e-08  0:01:18  379
   122 4.0517e-03 1.1658e-03 6.9475e-03 4.5863e-08  0:01:02  378
   123 3.9866e-03 1.1456e-03 6.8072e-03 4.5971e-08  0:00:50  377
   124 3.9227e-03 1.1275e-03 6.6702e-03 4.5167e-08  0:00:40  376
   125 3.8598e-03 1.1095e-03 6.5352e-03 4.7052e-08  0:00:32  375
   126 3.7982e-03 1.0919e-03 6.4032e-03 4.6118e-08  0:00:25  374
   127 3.7385e-03 1.0751e-03 6.2732e-03 4.6781e-08  0:00:20  373
   128 3.6798e-03 1.0585e-03 6.1466e-03 4.5614e-08  0:00:16  372
   129 3.6221e-03 1.0420e-03 6.0129e-03 4.6897e-08  0:00:13  371
   130 3.5654e-03 1.0257e-03 5.8812e-03 4.5266e-08  0:00:10  370
   131 3.5092e-03 1.0094e-03 5.7585e-03 4.6294e-08  0:00:08  369
   132 3.4548e-03 9.9443e-04 5.6282e-03 4.6604e-08  0:00:07  368
   133 3.4017e-03 9.7948e-04 5.5163e-03 4.5098e-08  0:00:05  367
   134 3.3498e-03 9.6428e-04 5.4094e-03 4.5279e-08  0:00:04  366
   135 3.2988e-03 9.4913e-04 5.3016e-03 4.6205e-08  0:00:03  365
   136 3.2486e-03 9.3441e-04 5.1919e-03 4.6975e-08  0:00:03  364
   137 3.1993e-03 9.2646e-04 5.0869e-03 4.5871e-08  0:00:02  363
   138 3.1511e-03 9.1126e-04 4.9832e-03 4.5222e-08  0:00:02  362
   139 3.1037e-03 8.9632e-04 4.8812e-03 4.6891e-08  0:00:01  361
   140 3.0571e-03 8.8126e-04 4.7792e-03 4.6031e-08  0:01:13  360
   141 3.0112e-03 8.6641e-04 4.6774e-03 4.8354e-08  0:00:58  359
   142 2.9664e-03 8.5191e-04 4.5782e-03 4.7313e-08  0:00:47  358
   143 2.9225e-03 8.3768e-04 4.4799e-03 4.7088e-08  0:00:37  357
   144 2.8792e-03 8.2390e-04 4.3790e-03 4.6953e-08  0:00:30  356
   145 2.8372e-03 8.1117e-04 4.2835e-03 4.6176e-08  0:00:24  355
   146 2.7960e-03 7.9924e-04 4.1938e-03 4.5695e-08  0:00:19  354
   147 2.7556e-03 7.8718e-04 4.1175e-03 4.6886e-08  0:00:15  353
   148 2.7164e-03 7.7535e-04 4.0449e-03 4.4898e-08  0:00:12  352
   149 2.6780e-03 7.6344e-04 3.9712e-03 4.6096e-08  0:00:10  351
   150 2.6410e-03 7.5137e-04 3.8951e-03 4.5631e-08  0:00:08  350
   151 2.6046e-03 7.3922e-04 3.8208e-03 4.5457e-08  0:00:06  349
   152 2.5687e-03 7.2721e-04 3.7477e-03 4.5054e-08  0:00:05  348
   153 2.5334e-03 7.1527e-04 3.6788e-03 4.4009e-08  0:00:04  347
   154 2.4989e-03 6.8250e-04 3.5715e-03 4.4962e-08  0:00:03  346
   155 2.4980e-03 7.6969e-04 3.8216e-03 4.5315e-08  0:00:02  345
   156 2.4355e-03 8.4282e-04 3.1348e-03 4.8425e-08  0:00:02  344
   157 2.4022e-03 7.5094e-04 3.8385e-03 4.5690e-08  0:01:10  343
   158 2.3689e-03 6.8766e-04 3.4785e-03 4.6027e-08  0:00:56  342
   159 2.3370e-03 6.6987e-04 3.2215e-03 4.5978e-08  0:00:45  341
   160 2.3372e-03 7.0094e-04 3.4448e-03 4.5666e-08  0:00:36  340
   161 2.2794e-03 8.4341e-04 2.8907e-03 4.5667e-08  0:00:28  339
   162 2.2486e-03 7.3346e-04 3.4772e-03 4.5988e-08  0:00:23  338
   163 2.2182e-03 6.6528e-04 3.1520e-03 4.5983e-08  0:00:18  337
   164 2.2178e-03 6.4534e-04 3.1755e-03 4.7171e-08  0:00:14  336
   165 2.1640e-03 7.9150e-04 2.6885e-03 4.6912e-08  0:00:11  335
   166 2.1353e-03 6.8647e-04 3.2140e-03 4.7676e-08  0:00:09  334
   167 2.1351e-03 5.8888e-04 3.0398e-03 4.6127e-08  0:00:07  333
   168 2.0832e-03 7.6556e-04 2.5550e-03 4.5872e-08  0:00:06  332
   169 2.0562e-03 6.6203e-04 3.0368e-03 4.5234e-08  0:00:05  331
   170 2.0567e-03 5.5284e-04 2.8733e-03 4.5928e-08  0:00:04  330
   171 2.0078e-03 7.3342e-04 2.4316e-03 4.4481e-08  0:00:03  329
   172 1.9822e-03 6.3753e-04 2.8781e-03 4.6471e-08  0:00:02  328
   173 1.9833e-03 5.2578e-04 2.7202e-03 4.6599e-08  0:00:02  327
   174 1.9368e-03 7.0222e-04 2.3190e-03 4.7965e-08  0:00:02  326
   175 1.9122e-03 6.0842e-04 2.7235e-03 4.5678e-08  0:00:01  325
   176 1.9134e-03 4.9977e-04 2.5795e-03 4.5951e-08  0:01:06  324
   177 1.8688e-03 6.6794e-04 2.2150e-03 4.5149e-08  0:00:52  323
   178 1.8451e-03 5.8006e-04 2.5776e-03 4.7575e-08  0:00:42  322
   179 1.8463e-03 4.7596e-04 2.4484e-03 4.6125e-08  0:00:33  321
   180 1.8037e-03 6.3593e-04 2.1153e-03 4.6639e-08  0:00:27  320
   181 1.8043e-03 4.5397e-04 2.4171e-03 4.7047e-08  0:00:21  319
   182 1.7623e-03 6.4028e-04 2.1085e-03 4.6472e-08  0:00:17  318
   183 1.7400e-03 5.4805e-04 2.3813e-03 4.6855e-08  0:00:13  317
   184 1.7420e-03 4.3478e-04 2.2287e-03 4.7856e-08  0:00:11  316
   185 1.7016e-03 5.9378e-04 1.9734e-03 4.7815e-08  0:00:09  315
   186 1.7026e-03 4.1847e-04 2.2064e-03 4.6510e-08  0:00:07  314
   187 1.6630e-03 5.9435e-04 1.9630e-03 4.6912e-08  0:00:05  313
   188 1.6640e-03 3.9916e-04 2.1069e-03 4.7344e-08  0:00:04  312
   189 1.6252e-03 5.8471e-04 1.9183e-03 4.5798e-08  0:00:03  311
   190 1.6263e-03 3.8567e-04 2.0303e-03 4.7530e-08  0:00:03  310
   191 1.5883e-03 5.7125e-04 1.8721e-03 4.8300e-08  0:00:02  309
   192 1.5897e-03 3.7318e-04 1.9603e-03 4.7776e-08  0:01:03  308
   193 1.5523e-03 5.5617e-04 1.8249e-03 4.7601e-08  0:00:51  307
   194 1.5539e-03 3.6132e-04 1.8945e-03 4.6364e-08  0:00:40  306
   195 1.5175e-03 5.4040e-04 1.7759e-03 4.7213e-08  0:00:32  305
   196 1.5189e-03 3.5033e-04 1.8334e-03 4.7913e-08  0:00:26  304
   197 1.4837e-03 5.2456e-04 1.7258e-03 4.7267e-08  0:00:20  303
   198 1.4849e-03 3.3970e-04 1.7713e-03 4.6916e-08  0:00:16  302
   199 1.4509e-03 5.0870e-04 1.6763e-03 4.7838e-08  0:00:13  301
   200 1.4520e-03 3.2937e-04 1.7142e-03 4.6721e-08  0:00:10  300
   201 1.4190e-03 4.9323e-04 1.6275e-03 4.5135e-08  0:00:08  299
   202 1.4199e-03 3.1926e-04 1.6590e-03 4.5851e-08  0:00:07  298
   203 1.3879e-03 4.7811e-04 1.5803e-03 4.5933e-08  0:00:05  297
   204 1.3887e-03 3.0944e-04 1.6061e-03 4.7001e-08  0:00:04  296
   205 1.3575e-03 4.6344e-04 1.5360e-03 4.7372e-08  0:00:03  295
   206 1.3583e-03 2.9993e-04 1.5544e-03 4.7652e-08  0:00:03  294
   207 1.3278e-03 4.4927e-04 1.4928e-03 4.7396e-08  0:00:02  293
   208 1.3285e-03 2.9073e-04 1.5039e-03 4.6609e-08  0:00:02  292
   209 1.2987e-03 4.3560e-04 1.4501e-03 4.8337e-08  0:00:01  291
   210 1.2993e-03 2.8177e-04 1.4579e-03 4.7695e-08  0:00:59  290
   211 1.2702e-03 4.2226e-04 1.4105e-03 4.7621e-08  0:00:47  289
   212 1.2710e-03 2.7304e-04 1.4119e-03 4.7260e-08  0:00:38  288
   213 1.2423e-03 4.0934e-04 1.3719e-03 4.7856e-08  0:00:30  287
   214 1.2434e-03 2.6464e-04 1.3693e-03 4.6613e-08  0:00:24  286
   215 1.2150e-03 3.7065e-04 1.3423e-03 4.8046e-08  0:00:19  285
   216 1.2164e-03 2.5443e-04 1.3289e-03 4.8029e-08  0:00:15  284
   217 1.1885e-03 3.6503e-04 1.3091e-03 4.5342e-08  0:00:12  283
   218 1.1900e-03 2.4871e-04 1.2894e-03 4.8901e-08  0:00:10  282
   219 1.1627e-03 3.5822e-04 1.2731e-03 4.7677e-08  0:00:08  281
   220 1.1642e-03 2.3975e-04 1.2435e-03 4.7110e-08  0:00:06  280
   221 1.1375e-03 3.5019e-04 1.2406e-03 4.7141e-08  0:00:05  279
   222 1.1390e-03 2.3372e-04 1.2081e-03 4.6655e-08  0:00:04  278
   223 1.1130e-03 3.4180e-04 1.2078e-03 4.8548e-08  0:00:03  277
   224 1.1144e-03 2.2761e-04 1.1722e-03 4.5334e-08  0:00:02  276
   225 1.0889e-03 3.3293e-04 1.1760e-03 4.6606e-08  0:00:02  275
   226 1.0903e-03 2.2141e-04 1.1391e-03 4.6594e-08  0:00:02  274
   227 1.0654e-03 3.2383e-04 1.1459e-03 4.6190e-08  0:00:01  273
   228 1.0668e-03 2.1527e-04 1.1081e-03 4.7065e-08  0:00:55  272
   229 1.0424e-03 3.1471e-04 1.1168e-03 4.6892e-08  0:00:44  271
   230 1.0437e-03 2.0920e-04 1.0763e-03 4.5604e-08  0:00:35  270
   231 1.0199e-03 3.0566e-04 1.0880e-03 4.6517e-08  0:00:28  269
   232 1.0213e-03 2.0316e-04 1.0489e-03 4.6183e-08  0:00:22  268
   233 9.9791e-04 2.9668e-04 1.0619e-03 4.7686e-08  0:00:18  267
   234 9.9934e-04 1.9728e-04 1.0185e-03 4.7437e-08  0:00:14  266
   235 9.7647e-04 2.8790e-04 1.0355e-03 4.7035e-08  0:00:11  265
!  236 solution is converged
   236 9.7787e-04 1.9151e-04 9.9209e-04 4.7047e-08  0:00:09  264
 楼主| 发表于 2007-6-2 14:40:44 | 显示全部楼层
请教关于FLuent计算时间问题
怎么没有人知道么?请高手帮帮忙。谢谢!!
 楼主| 发表于 2007-6-4 09:19:43 | 显示全部楼层
请教关于FLuent计算时间问题
急死了,请高人帮帮忙吧!
 楼主| 发表于 2007-6-5 09:24:25 | 显示全部楼层
请教关于FLuent计算时间问题
真郁闷
发表于 2007-6-14 09:03:39 | 显示全部楼层
请教关于FLuent计算时间问题
帮你顶一个!
发表于 2012-4-8 10:24:16 | 显示全部楼层
07年的问题了啊
