查看: 5612|回复: 5
紧急[求助]动画怎么不能保存成MPEG格式
发表于 2007-6-2 17:08:48 | 显示全部楼层 |阅读模式
麻烦各位高手:
    我的fluent算完了,在playback里可以显示动画,但是点writer存为mpeg就出问题,fluent出现下面的话:
    CX_Hardcopy_Window: error opening PPM file  .\sequence-1_1_0000.ppm.
CX_Hardcopy_Window: error opening PPM file  .\sequence-1_1_0001.ppm.
CX_Hardcopy_Window: error opening PPM file  .\sequence-1_1_0002.ppm.
CX_Hardcopy_Window: error opening PPM file  .\sequence-1_1_0003.ppm.
CX_Hardcopy_Window: error opening PPM file  .\sequence-1_1_0004.ppm.
CX_Hardcopy_Window: error opening PPM file  .\sequence-1_1_0005.ppm.
CX_Hardcopy_Window: error opening PPM file  .\sequence-1_1_0006.ppm.
CX_Hardcopy_Window: error opening PPM file  .\sequence-1_1_0007.ppm.
CX_Hardcopy_Window: error opening PPM file  .\sequence-1_1_0008.ppm.
CX_Hardcopy_Window: error opening PPM file  .\sequence-1_1_0009.ppm.
CX_Hardcopy_Window: error opening PPM file  .\sequence-1_1_0010.ppm.
CX_Hardcopy_Window: error opening PPM file  .\sequence-1_1_0011.ppm.
CX_Hardcopy_Window: error opening PPM file  .\sequence-1_1_0012.ppm.
CX_Hardcopy_Window: error opening PPM file  .\sequence-1_1_0013.ppm.
CX_Hardcopy_Window: error opening PPM file  .\sequence-1_1_0014.ppm.
CX_Hardcopy_Window: error opening PPM file  .\sequence-1_1_0015.ppm.
CX_Hardcopy_Window: error opening PPM file  .\sequence-1_1_0016.ppm.
CX_Hardcopy_Window: error opening PPM file  .\sequence-1_1_0017.ppm.
CX_Hardcopy_Window: error opening PPM file  .\sequence-1_1_0018.ppm.
Error message from graphics function Metafile reading (internal):
Error reading file ';E:\example\ziji-huade\chongdie0.2v0.5\sequence-1_0019.hmf'; at line 1
CX_Hardcopy_Window: error opening PPM file  .\sequence-1_1_0019.ppm.
Error reading file ';E:\example\ziji-huade\chongdie0.2v0.5\sequence-1_0020.hmf'; at line 1
CX_Hardcopy_Window: error opening PPM file  .\sequence-1_1_0020.ppm.
Error reading file ';E:\example\ziji-huade\chongdie0.2v0.5\sequence-1_0021.hmf'; at line 1
CX_Hardcopy_Window: error opening PPM file  .\sequence-1_1_0021.ppm.
"mpeg_encode  param1"
MPEG ENCODER STATS (1.5b)
TIME STARTED:  Sat Jun 02 16:43:43 2007
MACHINE:  unknown
FIRST FILE:  ./sequence-1_1_0000.ppm
LAST FILE:  ./sequence-1_1_0021.ppm
PATTERN:  i
GOP_SIZE:  12
SLICES PER FRAME:  1
RANGE:  +/-8
PIXEL SEARCH:  FULL
PSEARCH:  EXHAUSTIVE
BSEARCH:  CROSS2
QSCALE:  8 8 8
REFERENCE FRAME:  ORIGINAL
ERROR:  Couldn';t open input file ./sequence-1_1_0000.ppm
Removing frame files ...系统找不到指定的路径。
系统找不到指定的路径。
系统找不到指定的路径。
系统找不到指定的路径。
系统找不到指定的路径。
系统找不到指定的路径。
系统找不到指定的路径。
系统找不到指定的路径。
系统找不到指定的路径。
系统找不到指定的路径。
系统找不到指定的路径。
系统找不到指定的路径。
系统找不到指定的路径。
系统找不到指定的路径。
系统找不到指定的路径。
系统找不到指定的路径。
系统找不到指定的路径。
系统找不到指定的路径。
系统找不到指定的路径。
系统找不到指定的路径。
系统找不到指定的路径。
系统找不到指定的路径。
done.
这是什么意思,我该怎么做才能保存动画,谢谢了
发表于 2010-3-31 19:39:46 | 显示全部楼层
我也遇到了相同的问题,哪位高手帮帮小弟?不胜感激!
发表于 2010-3-31 20:13:30 | 显示全部楼层
刚才看了一下其他的论坛,有一种说法是在animate-define里,storage type要保存成PPM Image格式,可以试一下
发表于 2010-3-31 20:54:24 | 显示全部楼层
不认识英文么?搞成hardcopy files了
在animate-define里,storage type选择metafile格式,做完后write为mpeg格式,绝对可以!
发表于 2010-3-31 21:00:56 | 显示全部楼层
可以保存的,设置错了吧
发表于 2010-4-24 09:06:41 | 显示全部楼层
你好!我最近也遇到此种问题。
我通过如下方式进行了 解决:
1  先把 动画打开让其在fluent中  回放一边;(这一步一定要做)
2  在animate /play back 中的  write 和record format中选择hardcopy frames  ;点击右侧的 hardcopy options,打开对话框,在format栏下 选择PPM;点击保存;
3 再返回在animate /play back 中的  write 和record format中选择MPEG 重新wirte 一下 ,就能生成动画了。
你试一下!我试了下 可以!
希望对你有帮助。
还有一种方法:就是对屏幕进行录像了。
祝你成功!
