查看: 2464|回复: 2
fluent网格检查出现warning,求高人指点
发表于 2012-12-27 17:56:37 | 显示全部楼层 |阅读模式
用pointwise画了两个相贯圆柱的结构化网格,导入fluent后check 出现以下提示
Checking mesh.................
WARNING: The mesh contains high aspect ratio quadrilateral,
         hexahedral, or polyhedral cells.
         The default algorithm used to compute the wall
         distance required by the turbulence models might
         produce wrong results in these cells.
         Please inspect the wall distance by displaying the
         contours of the 'Cell Wall Distance' at the
         boundaries. If you observe any irregularities we
         recommend the use of an alternative algorithm to
         correct the wall distance.
         Please select /solve/initialize/repair-wall-distance
         using the text user interface to switch to the
         alternative algorithm.
Done.
是哪里出问题了  请高手指点,对计算结构影响大不
发表于 2012-12-27 18:53:03 | 显示全部楼层
回复 1# 牛儿快跑 的帖子
网格质量差  The mesh contains high aspect ratio quadrilateral,
         hexahedral
发表于 2012-12-27 19:30:19 | 显示全部楼层
回复 1# 牛儿快跑 的帖子
很正常 你的模型比较复杂的话 网格在某些地方扭曲的比较厉害 或者是哪个角度比较大 都会出现这种警告
