查看: 6953|回复: 1
Error: FLUENT received a fatal signal (SEGMENTATION VIOLATION).
发表于 2013-1-24 15:26:40 | 显示全部楼层 |阅读模式
Warning message from graphics function Delete_By_Key:
Either you have more than 32767 lights in a scene or
Hoops is very confused. The picture may not be right.
(Segment was '/driver/opengl'.)
No error handler available
Error Object: ()
计算过程出现如上错误,在网上也看到网友提到这个错误,但是没有具体的分析原因,希望高手给解释一下是什么原因。还有出现这个错误是,animate无法显示图像
发表于 2014-9-17 22:19:05 | 显示全部楼层
是的,我也有这个问题
这个问题,有时候是有的,但关了后从起,读入数据后,就没了,其实看教程里他们那也时常出这个Error: FLUENT received a fatal signal (SEGMENTATION VIOLATION).
Error Object: ()
