查看: 1858|回复: 1
gambit不能启动
发表于 2013-1-26 23:01:02 | 显示全部楼层 |阅读模式
我先安装了Exceed 13在D:\Program Files\Hummingbird目录,后装Gambit 2.4.6在D:\Fluent.Inc,启动时出现下列问题,请高手指教
Locating Exceed installation ...
gambit failed in locating Exceed installation on your system.
Please try to start Exceed manually before you run gambit.
Starting D:\Fluent.Inc\gambit2.4.6\ntx86\gambit.exe -device open -id default_id7544 -new  ...
FATAL ERROR: Could not obtain valid license authorization.
Total of 0.03 cpu second(s), 102400 maximum memory.
*** Cannot connect to license server
The server (lmgrd) has not been started yet, or
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Feature:       gambit
Server name:   SH200400N
License path:  D:\Fluent.Inc\license\ntx86\..\license.dat
FLEXlm error:  -15,10.  System Error: 10061 "WinSock: Connection refused"
available at "www.macrovision.com".
Feature:       gambit-addon
发表于 2013-1-27 09:05:42 | 显示全部楼层
是不是license过期了,论坛上好像有可以用的,或者改改时间试试。我也想装exceed13+gambit2.4.6,请问你是在哪下的。或者传我一份,965541012@qq.com。谢谢了
