查看: 2031|回复: 1
在linux中算fluent时采用解释性UDF时出错
发表于 2013-2-27 23:27:40 | 显示全部楼层 |阅读模式
20金钱
各位大侠,本人在linux中用fluent13加载UDF时出现了两个问题,盼望各位大侠施以援手
问题1:自己编写了一个UDF文件,在windows下进行解释和编译都没有问题,然而在linux(版本是ret hat enterprise linux5)下,对UDF进行解释时提示下面错误
Error:/root/zoupeng/thetmalconduct.c:line 2:syntax error.
在网上查询时,有人说时是格式不对,需要用dos2unix进行格式转换
然而在对thetmal.c这个UDF文件进行转换时,发现转换不成功:
[root@node1 ~]# dos2unix thetmalconduct.c
dos2unix: converting file thetmalconduct.c to UNIX format ...
dos2unix: problems converting file thetmalconduct.c
不知道是什么原因。
问题2:对另外一个UDF文件,在windows系统中解释和编译没问题,但在linux中编译时,进行build时没有提示错误,但是当进行load时,就会提示
Opening library "libudf"...
Primitive Error at Node 1pening_udf_library:No such file or directory
Primitive Error at Node 2pening_udf_library:No such file or directory
Primitive Error at Node 3pening_udf_library:No such file or directory
Primitive Error at Node 4:opening_udf_library:No such file or directory
Primitive Error at Node 5:opening_udf_library:No such file or directory
Primitive Error at Node 6:opening_udf_library:No such file or directory
Primitive Error at Node 7:opening_udf_library:No such file or directory
Primitive Error at Node 8:opening_udf_library:No such file or directory
Primitive Error at Node 9:opening_udf_library:No such file or directory
Primitive Error at Node 10:opening_udf_library:No such file or directory
Primitive Error at Node 11:opening_udf_library:No such file or directory
Primitive Error at Node 0:opening_udf_library:No such file or directory
Error:opening_udf_library:no error
ErrorObject:#f
请教论坛各位大侠,这是出了什么错误?
 楼主| 发表于 2013-3-1 16:05:51 | 显示全部楼层
由于windows下以\r\n结尾,而linux为\n结尾,故而会导致结果出错,可以自己编写一个小程序替换下。我在windows中,用Scite软件打开文件,再保存,能导入到linux中直接运算;也可以直接在linux中用vi将udf重新编写一
使用道具 举报
