查看: 4173|回复: 1
CFX在模拟离心泵过程中出错
发表于 2013-2-28 11:06:43 | 显示全部楼层 |阅读模式
ERROR #001100279 has occurred in subroutine ErrAction.             |
| ****** FATAL ERROR ****** The orthographic view transformation fa- |
| iled on domain interface "Domain Interface 1".  Failure may be du- |
| e to r=0 included in transformed cylindrical coordinates of an in- |
| terface with rotational relative motion.  Another reason could be  |
| that the interface contains faces that are parallel and others t-  |
| hat are perpendicular to the rotation axis.                        |
|                    Writing crash recovery file                     |
Details of error:-
Error detected by routine PEEKR
CDANAM = RTIME_DTEND
CRESLT = NONE
Current Directory : /FLOW/SOLUTION/TSTEP0/CLOOP0/ZN1
|                An error has occurred in cfx5solve:                 |
| The ANSYS CFX solver exited with return code 1.   No results file  |
| has been created.                                                  |
End of solution stage.
请大家帮忙看下,我把源文件上传在附件中
2013.rar
4.42 MB, 下载次数: 210
发表于 2013-5-16 15:31:50 | 显示全部楼层
interface网格问题吧 光滑一下应该就好了
