查看: 2846|回复: 3
mesh文件导入fluent后,check网格出现warning,但不知道错在什么地方,求大神指点。
发表于 2013-3-31 18:16:03 | 显示全部楼层 |阅读模式
Domain Extents:
   x-coordinate: min (m) = -4.982458e+001, max (m) = 1.080201e+002
   y-coordinate: min (m) = -3.066161e+002, max (m) = 3.066161e+002
   z-coordinate: min (m) = -4.399996e+001, max (m) = 2.284599e+001
Volume statistics:
   minimum volume (m3): 1.574398e-001
   maximum volume (m3): 4.586341e+000
     total volume (m3): 6.709472e+005
Face area statistics:
   minimum face area (m2): 2.897073e-001
   maximum face area (m2): 5.687396e+000
Checking number of nodes per cell.
Checking number of faces per cell.
Checking thread pointers.
Checking number of cells per face.
Checking face cells.
Checking cell connectivity.
Checking bridge faces.
Checking right-handed cells.
Checking face handedness.
Checking face node order.
Checking closed cells.
Checking contact points.
Checking element type consistency.
Checking boundary types:
Checking face pairs.
Checking wall distance.
Checking node count.
Checking nosolve cell count.
Checking nosolve face count.
Checking face children.
Checking cell children.
Checking storage.
Checking periodic boundaries.
   Periodic zone   6: x-translation: min (m) = 1.816789e+001, max (m) = 3.016409e+001
                      y-translation: min (m) = -4.711376e+000, max (m) = 1.794434e-002
                      z-translation: min (m) = 6.441226e-001, max (m) = 1.655054e+001
   Periodic zone   8: x-translation: min (m) = 1.702276e+001, max (m) = 2.936483e+001
                      y-translation: min (m) = -4.136620e+000, max (m) = 3.809057e+000
                      z-translation: min (m) = -1.039473e+001, max (m) = 9.106941e-001
   Periodic zone  10: x-translation: min (m) = 1.820261e+001, max (m) = 3.117543e+001
                      y-translation: min (m) = -1.950073e-002, max (m) = 4.306976e+000
                      z-translation: min (m) = 5.824254e-001, max (m) = 1.655054e+001
Done.
WARNING: Mesh check failed.
发表于 2013-4-3 21:11:17 | 显示全部楼层
还真看不出来你的网格有什么问题,建议你把网格传上来。
 楼主| 发表于 2013-4-3 22:23:11 | 显示全部楼层
回复 2# a2883524 的帖子
不多不多。能加你QQ吗?在这个论坛里我不知道怎么上传文件。
发表于 2013-4-7 11:09:32 | 显示全部楼层
发我邮箱把,a2883524@126.com
