查看: 1476|回复: 0
关于DUF 运行出现错误 请大家帮帮忙 看看怎么错了
发表于 2013-4-10 22:11:33 | 显示全部楼层 |阅读模式
(chdir "libudf")()
(chdir "ntx86\3d")()
6.c
..\..\src\6.c(2) : warning C4002: too many actual parameters for macro 'DEFINE_DPM_VP_EQUILIB'
..\..\src\6.c(44) : error C2065: 'Z' : undeclared identifier
..\..\src\6.c(44) : error C2100: illegal indirection
我的UDF 为
#include <udf.h>
DEFINE_DPM_VP_EQUILIB (raoult_vpe,p,cvap_surf,Z)
    int is;
    real molwt[MAX_SPE_EQNS];
    Thread *t0 = P_CELL_THREAD(p);  /* cell thread of particle location */
    Material *gas_mix = THREAD_MATERIAL(t0); /* gas mixture material */
    Material *cond_mix = P_MATERIAL(p); /* particle mixture material */
    int nc = TP_N_COMPONENTS(p);    /* number of particle components */
    real Tp = P_T(p);       /* particle temperature */
    real molwt_cond = 0.;  /* reciprocal molecular weight of the particle */
    for (is = 0; is < nc; is++)
         int gas_index = TP_COMPONENT_INDEX_I(p,is); /* index of vaporizing
            component in the gas phase */
         if (gas_index >= 0)
            /* the molecular weight of particle material */
            molwt[gas_index] =
           MATERIAL_PROP(MIXTURE_COMPONENT(gas_mix,gas_index),PROP_mwi);
            molwt_cond += TP_COMPONENT_I(p,is) / molwt[gas_index];
    /* prevent division by zero */
    molwt_cond = MAX(molwt_cond,DPM_SMALL);
    for (is = 0; is < nc; is++)  {
     /* gas species index of vaporization */
     if( gas_index >= 0 )
        /* condensed material */
        Material * cond_c = MIXTURE_COMPONENT( cond_mix, is );
        /* condensed component molefraction */
        real xi_cond = TP_COMPONENT_I(p,is)/(molwt[gas_index]*molwt_cond);
        /* particle saturation pressure */
        real p_saturation = DPM_vapor_pressure(p, cond_c, Tp);
        if (p_saturation < 0.0)
          p_saturation = 0.0;
        /* vapor pressure over the surface, this is the actual Raoult law */
        cvap_surf[is] = xi_cond * p_saturation / UNIVERSAL_GAS_C*****TANT / Tp;
  /* compressibility for ideal gas */
  *Z = 1.0;
