查看: 3018|回复: 0
关于VOF中调用volume fraction梯度的问题
发表于 2013-5-14 22:20:50 | 显示全部楼层 |阅读模式
大家好,我想用UDF把一个新的蒸发相变模型加入VOF模型中来计算液滴蒸发,液滴直径为100微米,初始温度为500K,周围空气初始温度为800K。网格尺寸1微米,步长0.1微秒。
公式中需要用到volume fraction的梯度。我用的C_VOF_G(cell, gas),编译能通过,也可以进行计算。但是计算结果中mass transfer rate 始终为0,然后我加入了printf来查看公式中的中间值,发现用C_VOF_G(cell, gas)获取的界面上的梯度值始终为0,而后处理中界面上的VOF gradient不是0。
UDF如下:
  1. /* UDF to define a simple mass transfer based on SunDongliang's equation. */
  2.
  3.   #include "udf.h"
  4.   #include "sg_mphase.h"
  5.   DEFINE_MASS_TRANSFER(liq_gas_source_Sun, cell, thread, from_index, from_species_index, to_index, to_species_index)
  6.   {
  7.     real m_lg; // mass transfer rate on the interface, kg/s/m3 ;
  8.     real T_SAT = 373.15; // saturated temperature, K
  9.     real h_lg = 2257600; // evaporation enthalpy, J/kg
  10.     real vof_cutoff = 0.05;
  11.     real vpVofT; // dot product of temperature gradient and volume fraction gradient
  12.     real v_sx; // volume fraction gradient dx
  13.     real v_sy; // volume fraction gradient dy
  14.     Thread *liq, *gas;
  15.     liq = THREAD_SUB_THREAD(thread, from_index);
  16.     gas = THREAD_SUB_THREAD(thread, to_index); //  from_index and to_index are defined in the Mass panel of Phase interaction.
  17.     m_lg = 0.0; // Initial value of m_lg.
  18.
  19.     if (NULL != THREAD_STORAGE(gas,SV_VOF_G))
  20.     {
  21.      v_sx = C_VOF_G(cell, gas)[0];
  22.      v_sy = C_VOF_G(cell, gas)[1];
  23.      }
  24.
  25.     if ((C_VOF(cell, liq) > vof_cutoff) && (C_VOF(cell, liq) < (1-vof_cutoff)))
  26.         {                                               // Evaporating, and it will be added to vapor phase governing equation
  27.         vpVofT = v_sx*C_T_G(cell, thread)[0] + v_sy*C_T_G(cell, thread)[1];
  28.           printf("v_sy: %f \n", v_sy);
  29.           printf("TempGradx: %f \n", C_T_G(cell, thread)[0]);
  30.           printf("dot product of TempGrad and VOFGrad: %f \n", vpVofT);
  31.         m_lg = 2/h_lg*C_K_L(cell, gas)*vpVofT; //NV_DOT(C_VOF_G(cell, gas), C_T_G(cell, thread));
  32.         }
  33.        return (m_lg);
  34.    }
复制代码
麻烦各位给分析下,先行谢过!
